Shift On The Fly Switch... - Ford Truck Enthusiasts Forums
Old 10-20-2010, 06:03 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is online now
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
Hey Guys,I had to pull a guy out of a rut the other night,went to put it in 4Hi and nothing,no 4X4 light on the dash or anything,what is the likely cause...fuse maybe,I haven't had any other issues or messed with anything else for it to be a fuse though...thoughts.....It's bad because I had to use Aprils' Tahoe to pull the guy out...I wasn't happy about that but of course she got some jawboning rights for a while...LOL
Old 10-20-2010, 09:11 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
I would check the fuse box under the dash, #28 loc.. 10A. Also check under the hood fuse box, #17 location, 30A.
Old 10-20-2010, 09:24 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Also check the relays under the hood.
My 99 4Hi and 4Lo relays are in this box. I was having a problem going into 4Lo and cleaned all the spade connectors on the relays with emory cloth and it started shifting into 4Lo again.
Can you hear the transfer case shift motor operate? If not check the connector at bottom driver side of transfer case.
Old 10-20-2010, 09:28 PM
Nope, I can't hear anything engage,like the switch is just dead.I haven't used it in a while,but the last time I used it,it worked.
Old 10-20-2010, 09:46 PM
PaysonPSD's Avatar
Check what Clint and I have suggested and let us know what you find and we can go from there.
Old 10-20-2010, 10:31 PM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
How long is "a while"? Months? Years? I do Guzzle's auto hub maintenance annually, but then, here in CO, it gets a workout in the winter months!
Old 10-21-2010, 07:19 AM
Quote:
Hubs have only been on for a few months now,I used 4x4 back over the winter a few times,but not since.After b-fast I'm going out to check the fuses and relays,I'll post back what I find. Thanks guys...
Old 10-21-2010, 08:05 AM
robs01f250 robs01f250 is offline
robs01f250 is gaining momentum as a positive member of FTE.
Your vacuum lines could be leaking causing your hubs not to lock in.
Old 10-21-2010, 08:18 AM
Ok guys,I think I figured it out.
Notice relays A&B,I was told buy a dealer(I know,this is what started it),that these two relay slots were for the charge line for my TT,so I bought these two relays and put them in and I guess the charge line wasd working this summer while towing.Well,after reading the replies from here I go out and switch relays A&B, with relays C&D,checked my SOTF switch and it works.Obviously A&B are for the SOTF,but are the other two for the charge line?,if not what are they for?......Thoughts...
Old 10-21-2010, 08:19 AM
OH boy,sorry guys,I have both sets marked A&B,C&D are the ones to the right...GOOD GRIEF CHARLIE BROWN.
Old 10-21-2010, 12:15 PM
crum71's Avatar
crum71 crum71 is offline
1/8 mile Oval Track
crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.crum71 has a great reputation on FTE.
Is your power windows working? After you check the fuses and if the are ok,maybe a wire came off the back? Reason I ask about the windows,when my GEM fried, it wouldn't light up for the 4x4 either. I also had a wire to pull out of the plug before is the reason I mention that also. Hope its something simple and easy to fix.
Old 10-21-2010, 05:49 PM
PaysonPSD's Avatar
Phil,
The ones closest to the firewall come with the trailer tow package.
They are for trailer batt charge and I belive trailer back up lights
The ones toward front of truck are for ESOF. These relays should have two sets of contacts in them, one make and one break.
The ones for trailer tow only have make contacts. You can't swap them.
Both ESOF relays in my truck are FOAB-14B192-AA.
Bottom side of relays.
The ESOF relays have 5 posts. When relay operates contact 87a opens and contact 87 closes.
The trailer tow relays only have 4 posts. There is no 87a.
There should be a schematic right on the relay showing the contact arrangement.
The five post relay will work in place of the 4 post, but the 4 post will
not work in place of a 5 post if the break contact is used in the circuit.
Hope I haven't confused you.
Old 10-23-2010, 12:12 PM
Sorry for taking so long to post back guys,I just got back in town a few mins. ago.Thanks for the help,so can I switch the two relays closest to the firewall with the other two,I know the ESOF will work because I switched them and it worked,but will the other two relays work right for the trailer towing?
Old 10-24-2010, 10:09 PM
PaysonPSD's Avatar
They should Phil. All you need are two relays with just make contacts.
In other words the 4 post relays should work for trailer tow relays.
5 posts will work as well if the trailer toe relay socket has 5 female sockets.
Old 10-25-2010, 12:28 AM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Robin has your answer.
The relays shown in the ESOF "doghouse" are SPST relays, which should be SPDT.
IF the Trailer-tow package relays are SPDT, and you swap them for the ESOF ones, everything should work afterward.
Pop
1994 Aerostar fuse that controls overdrive torque converter lockup AeroZona Aerostar 27 11-21-2016 09:19 PM
Problems with EEC fuse blowing on 94 Ford Explorer 94FordMan77 Electrical Systems/Wiring 1 04-07-2014 02:47 PM
Brake light fuse blew. 351Cleveland C4 1967 - 1972 F-100 & Larger F-Series Trucks 12 01-20-2014 07:49 PM
04 Upfitter switch fuse locations xmontex4 1999 to 2016 Super Duty 3 07-20-2013 10:36 PM
HELP! Blowing ignition switch fuse IamToyoftherm 2004 - 2008 F150 17 09-08-2012 10:23 PM
Tags
14b192, 99, aa, duty, esof, expedition, f250, f5b14b192a, fly, foab, foab14b192aa, ford, relay, shift, super, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
