1951 F1 V8 air cleaner will not stay on
Is the top of the carb flat, like a pipe, or does it have a wedge shape? There are different types of Holley 94 carbs with different arrangements. The truck should have the wedge-shaped top, like the one on the right top below. Likewise the air cleaner needs to be the type that fits over the wedge.
The bottom of the air cleaner is flanged so it sits over the top of the flange on the carburetor. There's also a circular bracket that is flanged and contoured to follow the flange/contour of the flange on the carburetor and air cleaner. Your air cleaner won't stay on if you don't have the bracket or if the air cleaner is flat at the bottom opening, when it should be flanged.
Cougar54
13
03-16-2014 11:40 PM
41505379
07-19-2013 06:55 PM
