4.2L O2 sensor location
Old 10-19-2010, 08:52 AM
kbgrn150's Avatar
kbgrn150
kbgrn150 is offline
Hi Folks
Have fault in bank2 sensor 1 (upstream?) Mechanic that inspected it said bank 2 is driver side and bank 1 is passenger side of vehicle. Parts store guy says it's the opposite. So who's right? Thanks for the help
kbgrn150
Old 10-19-2010, 02:12 PM
BrianA's Avatar
BrianA
BrianA is offline
Unless I am badly mistaken, Bank 1 is the side with #1 cylinder.
In the case of the 4.2, #1 cylinder is the front cylinder on the passenger side.
To verify, you can always look at the coil pack, find the #1 wire (connections are numbered with small numbers molded into coil pack assembly) and follow the #1 wire to the #1 cylinder.
Old 11-11-2010, 11:07 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Bank 2 sensor 1 was easiest for me to reach through the drivers side (left) wheelwell by turning the wheel full lock left.
Old 11-12-2010, 06:32 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
Replace both sides.
Old 11-13-2010, 11:27 AM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
if it ain't broke, don't fix it
Originally Posted by BlueOvalFitter
Replace both sides.
If money's tight, all you need to replace is the one throwing a code. I would bet that is why he wanted to know which side is which.
Old 12-19-2010, 12:41 PM
love a ford's Avatar
love a ford
love a ford is offline
help me
Originally Posted by kbgrn150
Hi Folks
kbgrn150
howdy ,did u find out which one it is ? my trucks outside now n i dont know which one . ! .ive got the sensor and the socket . im learning how to do this stuff myself id like to believe ur mechanic ! but its looks like 2 ,one on each side 2003 f150 xl 4.2 6cyl thx frnd .....mike
Old 12-19-2010, 12:45 PM
BlueOvalFitter
Thumbs up
Always replace 02 sensors in pairs.(Unless your vehicle only has one)
Old 03-07-2022, 01:20 AM
JDBalkyinjection598cu.in's Avatar
JDBalkyinjection598cu.in is offline
bank 1 is no1 cylinder bank 2 is no2 cylinder on the 4.2 v6 no1 should be right side or passenger side
Old 05-26-2022, 07:56 PM
Taz99F150's Avatar
Taz99F150
Taz99F150 is offline
5th Gear
You are correct. Replaced this a month ago.
Old 05-26-2022, 08:15 PM
BlueOvalFitter
Question
And? Did it fix the problem?
Old 05-26-2022, 09:13 PM
Taz99F150's Avatar
Taz99F150
5th Gear
Yep. No more check engine light. Didn't replace in pairs though. Just replaced the one side.
hofec1
2004 - 2008 F150
37
11-26-2020 01:45 PM
Grayson2120
2004 - 2008 F150
08-02-2017 02:51 PM
Bentizzy
2004 - 2008 F150
37
08-29-2016 09:23 AM
teamlx88
1997-2006 Expedition & Navigator
09-28-2012 10:41 PM
kbgrn150
08-29-2010 11:54 PM
Quick Reply: 4.2L O2 sensor location
