4.2L O2 sensor location - Ford Truck Enthusiasts Forums
Old 10-19-2010, 09:52 AM
kbgrn150 kbgrn150 is offline
kbgrn150 is starting off with a positive reputation.
Hi Folks
Have fault in bank2 sensor 1 (upstream?) Mechanic that inspected it said bank 2 is driver side and bank 1 is passenger side of vehicle. Parts store guy says it's the opposite. So who's right? Thanks for the help
kbgrn150
Old 10-19-2010, 03:12 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
Unless I am badly mistaken, Bank 1 is the side with #1 cylinder.
In the case of the 4.2, #1 cylinder is the front cylinder on the passenger side.
To verify, you can always look at the coil pack, find the #1 wire (connections are numbered with small numbers molded into coil pack assembly) and follow the #1 wire to the #1 cylinder.
Old 11-12-2010, 12:07 AM
Sam I Am's Avatar
Sam I Am Sam I Am is online now
Sam I Am is gaining momentum as a positive member of FTE.Sam I Am is gaining momentum as a positive member of FTE.
Bank 2 sensor 1 was easiest for me to reach through the drivers side (left) wheelwell by turning the wheel full lock left.
Old 11-12-2010, 07:32 PM
BlueOvalFitter's Avatar
BlueOvalFitter BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
Replace both sides.
Old 11-13-2010, 12:27 PM
Sam I Am's Avatar
if it ain't broke, don't fix it
Quote:
Originally Posted by BlueOvalFitter View Post
Replace both sides.
If money's tight, all you need to replace is the one throwing a code. I would bet that is why he wanted to know which side is which.
Old 12-19-2010, 01:41 PM
love a ford love a ford is offline
love a ford is starting off with a positive reputation.
help me
Quote:
Originally Posted by kbgrn150 View Post
Hi Folks
kbgrn150
howdy ,did u find out which one it is ? my trucks outside now n i dont know which one . ! .ive got the sensor and the socket . im learning how to do this stuff myself id like to believe ur mechanic ! but its looks like 2 ,one on each side 2003 f150 xl 4.2 6cyl thx frnd .....mike
Old 12-19-2010, 01:45 PM
Thumbs up
Always replace 02 sensors in pairs.(Unless your vehicle only has one)
bank 1 bank 2 teamlx88 1997-2006 Expedition & Navigator 11 09-28-2012 11:41 PM
98 F150 Intake Manifold Runner Control valve problem kbgrn150 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 08-30-2010 12:54 AM
bank1 vs bank 2 motorhead748 Explorer, Sport Trac, Mountaineer & Aviator 3 10-08-2009 07:59 AM
which side is bank 2? chevyjr73 Modular V8 (4.6L, 5.4L) 2 12-31-2004 12:21 PM
Is Bank 1 on passenger or driver side? kamsho 1997-2006 Expedition & Navigator 6 11-03-2003 11:09 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
03, 2002, 42, 42l, bank, engine, f150, ford, location, o2, oxygen, sensor, sensors, side, tool, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
