Gas smell in cab - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Gas smell in cab
Old 10-19-2010, 12:41 AM
vtjvt's Avatar
vtjvt vtjvt is offline
vtjvt is starting off with a positive reputation.
Gas smell in cab
Ok I have tried searching and can't find my specific problem so Here goes.
1990 bronco 5.8 liter.
When I am going down the road and get on the throttle hard I have a bad gas smell inside the bronco when I let off the throttle. smells like raw gas. It doesn't happen with normal driving. I also get gassed out when I am bouncing around offroad. it gets worse the harder i push it. I can't find any leaks there is no gas in the oil or exhaust. It runs great just stinks. any ideas??
Old 10-19-2010, 02:20 AM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Are the windows rolled up?
is there a hole in the floor? Out back above the fuel tank where somebody thought it was a good idea to make it easier to remove and replace the fuel pump instead of dropping the tank?
That's two ideas?
Old 10-19-2010, 07:48 AM
vtjvt's Avatar
No holes in the floor that I can find. and windows up or down still smells. I wonder if the fuel pump isn't sealed all the way.
Old 10-19-2010, 01:05 PM
gjnicholas's Avatar
gjnicholas gjnicholas is offline
gjnicholas is starting off with a positive reputation.
mine was like that after i changed the fule sender float it turned out i didnot get a good seal hard to see where it was coming from had to get under and feel the sensor to find it
Old 10-19-2010, 07:51 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Check the fuel rail and regulator for signs of leaks. Remember, EFI is under 35-40 PSI during normal operation.
Old 10-19-2010, 10:38 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant futureEncho has a brilliant future
How is your exhaust doing these days? if you own a Bronco, the exit of the exhaust should be behind the rear passenger side's wheel, facing the side, not the rear. If by some coincidense it's facing the real that could be the cause of the smell (you still have some other issue to work out first). Bad combustion of the fuel (if the smell actually comes from the exhaust) could be caused by a dead cylinder or fouled spark-plugs.
Old 10-20-2010, 12:30 AM
vtjvt's Avatar
Exhaust is only a year old and exits in the stock location. Engine is running fine It just passed the emissions test 3 weeks ago with flying colors.
Thanks for all the input so far. keep the ideas coming I am hoping to get a few minutes tomorrow after work to check some of the areas mentioned.
Old 10-20-2010, 01:22 PM
Hold on are you smell fuel or exhaust?
Old 10-20-2010, 07:14 PM
vtjvt's Avatar
Quote:
Fuel.
I just crawled under it again, I still can't see anything out of the ordinary. Maybe I will just drop the tank for a better look.
Old 10-20-2010, 09:05 PM
Ok. I was beginning to think I had misread your original post. If the smell is coming into the cab, I'd be more concerned about a leak in the engine bay or even at the filter which is directly beneath you (driver) on the frame rail.
Old 10-20-2010, 09:52 PM
vtjvt's Avatar
Just spent a hour crawling all over the bronco. I can't find a sign of a fuel leak anywhere. tank is dry, lines and filter are dry, injectors are also bone dry. I tested the pressure regulator and it holds vacuum great.
Is there a vent of check valve in the tank?? With normal everyday driving I don't have any problem. I am sick of getting a headache when out playing. Thank god I quit Smoking.
Old 10-20-2010, 10:08 PM
vtjvt's Avatar
The reason I ask about the vent is because there is a "T" in the top of the tank. 1 line runs up towards the front, I am assuming to the vapor canister the other runs to the back by the bumper and is capped off. I pulled the cap and tried blowing into it and it is plugged
Old 10-21-2010, 01:11 AM
There is a vent cap, should have a hose that runs up to the engine compartment, It's for vapor recovery emissions control. it's a vacuum line not a pressure line, if you suck on it it should give, but don't suck too much.
There should be two lines coming offf the fuel pump, one for supply one return gas to tank. Pictures of the tank are in my garage.
Old 10-21-2010, 01:13 AM
Two of the three holes in the tank are seen here, this is looking at the front of the tank.
Filler hole is to the right out of sight.
Old 10-21-2010, 08:55 PM
vtjvt's Avatar
Well crawled all over her again. Still can't find the fuel problem. On a positive note I found one of my vacuum canisters had a big hole in it which = big vacuum leak. Fixed that and my trans shifts normal now. and she runs alot better (imagine that).
intermittent gas smell cappo 1968-2013 Full Size Vans 5 08-28-2014 07:41 PM
Bronco issues :/ Watfordr 1978 - 1996 Big Bronco 3 07-09-2014 06:53 PM
how do i know if i need to replace the catalytic converter in my ford bronco 1994 Samantha21 1978 - 1996 Big Bronco 32 04-08-2013 05:15 AM
'56 F100 gas smell, in cab tank? Buford 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-18-2010 10:18 PM
Bad sulfur smell Judieh Explorer, Sport Trac, Mountaineer & Aviator 8 10-18-2006 01:36 PM
Tags
2003, 92, bad, bronco, cab, canister, early, excursion, exhaust, f150, f250, f350, ford, fuel, gas, hood, inside, problem, smell, smells
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
