1993 F350 7.3 engine swap - Ford Truck Enthusiasts Forums
Old 10-18-2010, 10:29 PM
fishnwild1 fishnwild1 is offline
fishnwild1 is starting off with a positive reputation.
I am looking to put a remanufactured engine in my 1993 F350 that has the .7.3 diesel ( non turbo, with a serpentine belt). My brother found a drop in 7.3 remanufactured by DealersDiesel, but the part number indicates it is for 1988 to 1992 and was for a van. Can this be made to work? Also is there a difference if the engine had a manual or automatic transmission hooked to it? mine is manual.On the "new" engine, the fuel filter is on the opposite side, it has pulleys for regular belts, and my brother thinks the end of the crankshaft looks like it is for an automatic. thanks for your input.
Old 10-18-2010, 10:34 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
The dip stick will be longer, and fuel filter on the driver side if it's for a Van.
Other than that, no difference, you can put a van engine in a truck, but can't put a truck engine in a van without moding it.
No difference auto or standard transmission other than the fly-wheel.
Can I ask what happen to the other 7.3?
Old 10-18-2010, 10:57 PM
thanks for the info. The engine still runs, but weak after 300,000 miles of dirty Alaska marine fuel, the whole fuel injection systems bad. Originally I was just looking for a fuel injector pump, and maybe some .injectors, but my brother who works for a big diesel outfit found this engine cheaper than a pump, and all that is included.
Old 10-18-2010, 11:03 PM
Ah ok, cause i'm sure with just a new fuel system she'll be as good as new!
But if you can get a good strong 7.3 for cheaper than an IP, then why not?
99 F350 7.3 running bad when locked into first gear Nitro 54 1999 - 2003 7.3L Power Stroke Diesel 1 11-15-2015 01:01 PM
99 F350 7.3 Nitro 54 1999 to 2016 Super Duty 0 11-12-2015 10:15 PM
1993 7.3 owners manual BFussner 1987 - 1996 F150 & Larger F-Series Trucks 2 09-26-2013 10:22 PM
My F350 eats serpentine belts! Wot am I doing wrong? Victorita 1999 to 2016 Super Duty 9 11-18-2011 07:00 PM
1993 Ford E350 7.3 serp Belt Routing Diagram dozerd12r Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 12-27-2003 10:15 AM
Tags
1987, 1993, 1996, 73, 73l, 93, belt, diesel, e350, engine, f350, f450, filters, ford, motor, swap, swaping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
