Program new key and remote - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 01-05-2000, 11:15 PM
JJR JJR is offline
JJR is starting off with a positive reputation.
Old 01-31-2001, 01:52 PM
forwheelin forwheelin is offline
forwheelin is starting off with a positive reputation.
I bought a used 99 Expedition and was given only one key and remote. I went to a dealer and bought a new key (they cut it) and remote. Dealer was busy and told me it would be several hours to program new key and remote.
Have stopped by several dealers and they all tell me I need to leave the vehicle for several hours until they can get to it. I know this takes them a minute or 2 to do.
Is this something I can do myself? If so where can I get detailed instructions.
Thanks
Old 02-01-2001, 02:08 AM
nitro94's Avatar
nitro94 nitro94 is offline
nitro94 is starting off with a positive reputation.
Your owners manual has the instructions for programing remotes and new keys.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old 02-02-2001, 08:20 AM
According to the manual:
"Take ALL your vehicles transmitters to your dealer for reprogramming." Nothing about keys that I can find.
I just don't want to spend 2 hours plus at a dealership for them to take 2 minutes to do this and then give them $50 for it.
Not what I call a good value for my time and money.
Old 02-03-2001, 12:30 AM
nitro94's Avatar
I stand corrected, you need 2 previously programed keys and then you can follow the instructons in your owners manual for programing extra keys. At least my 2000 f150 manual has this info. It also has the info for programing a new remote when you have lost one. I would be more than happy to relay the info. for remotes if you like but it sounds like the dealer is going to have to help anyway.
I would purchase another key and have three on hand so If one is lost you still have two to program with. By the way you can only add extra keys 8 times. After that it won't accept any further attempts.
Old 02-04-2001, 12:53 AM
dae dae is offline
dae is starting off with a positive reputation.
To program the extra key, you'll have to have the dealer do it since you only have one key. You can do it yourself only if you have 2. Previously to '99 it was possible to do with just one key. Now to program the extra remote(s), take your key and start in the accessories on position (Don't start the truck) the go to of position and back to accessories on. You need to do it like 8 or 10 times with in 5 seconds or so. Basicly just keep gong from the on, off to on position until you hear you electric locks cycle in the doors then press the lock button on every remote remote you want to program (It can recognize up to 4 remotes). When you do this with each remote, you'll hear the locks cycle also. BTW, make sure when you stop turning the ignition key from on (accessories) to off postion that you stop in the ON position when the locks cycle. Also make sure you program even you original remote because this process clears all remotes.
- Dae
Old 03-01-2001, 10:47 AM
janjaz janjaz is offline
janjaz is starting off with a positive reputation.
For anyone who has a 1997 Exp., it is possible to program a second key yourself. I went to one dealership and they swore up and down that I had to have both keys and alot of money but I knew from this forum that I could do it and it didn't say anything in the manuals about the key system. Went to another dealership and they didn't think I would be able to do it myself either. They cut a key for me and turn the truck on and off with the first key and then put the second key in and it turned right over. So luckily I only had to pay the price of the second key. Hope this helps someone out.
Old 03-11-2001, 07:05 PM
jimmer jimmer is offline
jimmer is starting off with a positive reputation.
>a new key (they cut
>busy and told me it
>they all tell me I
>can get to it. I
>minute or 2 to do.
it takes at least 2 keys allready programed keys for you to do it yourself, so the several hour wait is a must sometimes we just get busy, first come first serve, make an app. for later and then maybe youll be able to wait. there is a computer that has to be used when only 1 key is programmed.
>Thanks
Old 08-23-2011, 05:59 PM
Bear70 Bear70 is offline
Bear70 is starting off with a positive reputation.
HELP!! Trouble with rekeying 03 f150
I've got an 03 f150, I've got 2 keys but when I tried to program another 1(command start) it wouldn't let me. When I talked to a lock smith he informed me that there were no programming spaces left on the truck. Does anyone know if the old keys(that I don't have) can be erased?
Old 08-23-2011, 09:16 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
[quote=jimmer;81781it takes at least 2 keys allready programed keys for you to do it yourself, [/quote]
Just to be clear:
1997-1998 Expy, which has the PATS Type "A" System only requires ONE key and no scan tool to add another programmed key. It can be programmed for up to 16 keys.
1999 -2002 uses the Type "C" PATS and requires TWO working keys and no scan tool to add another programmed key. It can be programmed for up to 8 keys.
2003 - 2005 uses the Type "E" PATS and requires TWO working keys and no scan tool to add another programmed key. It can be programmed for up to 8 keys.
If the maximum number of keys have been programmed and you need to add another key, a scan tool is needed to erase key memory.
The Type "A" System is a stand alone system and the type "C" system is integrated into the instrument cluster. They will not keep the vehicle from cranking over with an invalid key, but will disable the fuel injectors.
The type "C" system is integrated into the PCM and has starter interupt capability if an invalid key is used.
Old 08-25-2011, 01:04 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
Are you sure? I was under the impression that when you program an additional key, the first one gets bumped out. A first in first out type of system.
Old 08-25-2011, 03:35 PM
Quote:
Originally Posted by alloro View Post
Are you sure? I was under the impression that when you program an additional key, the first one gets bumped out. a first in first out type of system.
Not on the PATS Type A C or E.
That sounds like you are thinking of some of the aftermarket remote start systems.
Old 08-25-2011, 04:50 PM
Unhappy
Thanks, I guess I'm off to the DEALER
Old 08-26-2011, 12:21 PM
Turx Turx is offline
Turx is starting off with a positive reputation.
Just went through this with the 01 Expedition I picked up. Since I only had one key I had to go to the dealer. I had them erase any old keys and reprogram the original and new key. Took about 20 minutes, cost for the key/cut $10.60, shop time $60.00. I did the remotes myself, easy process. I had already located the door access code under the dash. Went through the same thing when I bought the 99 Expedition. As mentioned, if you have two keys you can program another one yourself.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
00, 2001, car, expedition, f150, ford, key, keys, problems, program, programmed, programming, remote, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
