NOS REAR FENDER?
O.K. you asked for it
Anyway to get ahold of "numberdummy"?
c4az-98742-a Throttle kit
59c-8123342-a Handle
coaf-15499-f back up lights
c6az-13b712-a Wire assy
c7az-13786-a body and socket assy
c2az-13786-a body and socket assy
autolite vacuum control dd-12 codf-12370-a
c7ab6222614-a door handles
c7az-13788-a or c7az-18788-a hard to read the second number/lens assy
taaa-6068-a insulator
c4az-9365-a gas filter
c3az-10884-a temp sender
c1tz-6a666-a pcv valve
7ra-12300-c condenser
cotf-a?a024-a dimmer switch hard to read second number
c0ab-71605a24-a latch assy
c0tz-13a024-a dimmer switch
9-15 T.C. Regulator TC-4327E
Thanks for any help you guys/gals can give me. Damian.
^ ^ Right here. ^ ^
B7C16312A (replaced BAAA16312A) .. Flareside Pickup Right Rear Fender / Obsolete
Last MSRP: $275.50 // Last FoMoCo dealer net cost: $165.30.
Fits: 1953/67 F100/350 / 1968/69 F350-135" wheelbase only / 1968/79 F100/250.
It would take...at least...five hours to look up all the myriad applications for this list of parts in NINE different parts catalogs. I'd rather not do it.
You can google the part numbers, but I guar-an-tee some will not be listed. Some of the applications are multiples for cars/trucks, some are ID numbers, not part numbers.
For examples: C0TZ13A024A .. Dimmer Switch fits myriad Passenger Cars/Trucks/Bronco's and Econolines from 1960 thru 1996.
C0AF15499F is a dealer installed backup light kit for 1960 Ford Custom/Fairlane/Galaxie Passenger Cars.
C4AZ9365A is a fuel filter-fits into a metal cannister that threads onto the fuel pump for 1960/72 cars/trucks.
C1TZ6A666A is a smog valve for 1961/66 Passenger Cars/Trucks. Threads into the intake manifold of V8's.
I thought about it, and there's no way Julie, I'm not looking up all these parts and listing their applications.
I'll do a few, but that's about it.
I've been away for 15 days, so it's taken me the last two days just to play "catch up" in the 1961/66 forum.
There's only so much I can do.
Ifin you had all the necessary parts catalogs, would you spend hours lookin' up all these applications?
damian208
11-20-2014 09:54 AM
damian208
07-30-2014 11:18 PM
acgwinn
11-07-2010 12:02 PM
damian03
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
12-29-2003 11:06 PM
