4.6L Compression Testing... - Ford Truck Enthusiasts Forums
Old 10-18-2010, 03:34 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Alright, guys... you probably haven't seen me in here before because I hang out in the 7.3L and Super-Duty section of the threads. I'm kinda ignorant when it comes to gassers so I need a little help. I have a buddy who has a 4.6L in his Crown Victoria (it was an ex-cop car and was regularly maintained)... it's not an F-150, but it's the same motor. Anyways, he's noticed that in the past 3000 miles, it's used up over a quart of oil. It's got 145,000 miles and it doesn't smoke (at least, not enough to be noticeable)... we're gonna check out the cooler first to make sure it's not leaking oil into the coolant, but if not, we're gonna do a compression test. I found a pretty good writeup on testing the compression here, but I would like to know what "within specs" is for little or no oil consumption... I know each cylinder should be within 10PSI (or 75%) of eachother, but even if they were, they could be weak enough to burn oil. Any info I could get off y'all would be appreciated! Thanks, guys!
Old 10-18-2010, 04:21 PM
kaboom10's Avatar
kaboom10 kaboom10 is offline
kaboom10 is starting off with a positive reputation.
What I got from AllData. The indicated compression pressures are considered within specification if the lowest reading cylinder is within 75 percent of the highest reading.
Old 10-19-2010, 06:04 PM
n3up's Avatar
n3up n3up is offline
n3up is starting off with a positive reputation.
A quart in 3000 miles really isn't a whole lot of oil use, especially with 145000 on the clock.
Just confirm there's no leak and drive on.....
Hard start when engine cold Revolv 1999 - 2003 7.3L Power Stroke Diesel 37 12-16-2015 05:27 AM
advice on 2001 4.6L engine problems and swap MSwitchblade 1997 - 2003 F150 3 07-17-2015 10:57 AM
Advice on 2001 4.6L engine problem and swap MSwitchblade 1997 - 2003 F150 2 07-15-2015 10:55 PM
04 6.0 with NO compression on 6 Cylinders, Why? sosasser 6.0L Power Stroke Diesel 74 12-19-2014 06:40 AM
Compression Numbers/White Smoke nmrickie Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 06-30-2013 02:38 PM
Tags
1997, 2001, 46, 46l, 75l, checking, compre, compression, f150, ford, jon, spec, ssion, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
