Gas pump shuts off repeatedly when filling 2002 Explorer - Ford Truck Enthusiasts Forums
Old 10-17-2010, 07:27 PM
Scooter Explorer1 Scooter Explorer1 is offline
Scooter Explorer1 is starting off with a positive reputation.
Help please
A few weeks ago I had trouble filling up while on a trip, I figured the pump at the station had too high of pressure. I still am experiencing this at other stations locally now. I have to fill at half speed or below. Does anyone know what could be causing this? None of the hoses appear to be collapsed going to the fuel tube.
Thanks
Old 10-18-2010, 10:12 AM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
My E250 did this except worse. It would take 30 minutes to put in 35 gallons. That required an immediate fix. One of the vent hoses was clogged with a white chalky substance. It required tank removal to finally find it.
Old 10-18-2010, 01:20 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Sounds like an issue with the vent solenoid system, which is probably the system incorporating the tube the ncranchero makes reference to. It seems that several makes and models of cars have issued TSBs for similar issues, you might see if there are any that apply to your Explorer.
-Rod
Old 10-18-2010, 05:59 PM
Thanks Guys
I'll see what I can find out
1997 Explorer - fuel fill SLOW! SoCalAngler Explorer, Sport Trac, Mountaineer & Aviator 9 07-28-2016 11:08 AM
Broke Down - Spring, Texas Capt.Schenk 1999 - 2003 7.3L Power Stroke Diesel 18 10-09-2014 05:18 AM
Fuel fill Problem pdleonard Fuel Injection, Carburetion & Fuel System 1 09-01-2014 04:26 PM
large filler neck for fuel tank hotrodfeguy 1999 - 2003 7.3L Power Stroke Diesel 11 08-30-2014 01:02 AM
2001 fuel fill up issue Gwilkrrs Explorer, Sport Trac, Mountaineer & Aviator 4 05-04-2014 08:25 AM
Tags
2002, 2011, clicks, explorer, f150, filling, flex, ford, gas, pomp, pump, refueling, shuts, shutting, sport, turck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
