92 f250 rear main seal - Ford Truck Enthusiasts Forums
Old 10-17-2010, 03:02 PM
robjames46 robjames46 is offline
robjames46 is starting off with a positive reputation.
gotta 92 f250 with a 351w in it how do i change out the rear main seal i was lookin around on the internet to find a quick answer somewhere i found older trucks all u have to do is pull the oil pan but wat is the deffintion of older trucks idk am i this lucky?
Old 10-17-2010, 03:15 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
RMS job requires trans. to be dropped........sorry.
Old 10-17-2010, 03:19 PM
but then what once i get the tranny out is the seal right there
Old 10-17-2010, 03:31 PM
Old93junk's Avatar
Quote:
Yes, care must be taken when removing old seal to not damage shaft or you will be back at square one in short order. Re-installing seals is a operation in patience, surface cleaning prep, properly driving them in (flat- proper tool) and seating at correct depth.......plenty of prof. mechanics fail at this because they are in a hurry, do it right and you wont have to do it again.
Old 10-17-2010, 04:00 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
-Remove trans
-Remove flywheel/flexplate
Theres the seal, around the crank. I normally remove them using 2 self tapping screws inserted into the seal 180* apart. But be VERY careful when installing the screws to NOT touch the crank, or you WILL scratch it and it will NEVER seal again. Grab one screw w/ a vice grip, and pull it out, you may need to pry it w/ a prybar, sometimes on the newer trucks you cant just pull it out.
-To install new seal, you will need a seal driver to get it in straight and all the way in. I found a short piece of PVC pipe the same diameter as the seal, w/ one end capped, works well as a home made seal driver.
Tips:
-Make sure to lightly oil the seal lip before sliding it over the crank, helps prevent tearing of the seal in the short time there is no oil on the other side of it at first start up
-also i recommend using permatex ultra black around the OUTSIDE diameter of the seal, ive found if you just install them as is you have a 50-50% chance of oil leaking around the outside diameter after installation.
Hope this helps!
Old 10-17-2010, 06:01 PM
jrwhitmire jrwhitmire is offline
jrwhitmire is starting off with a positive reputation.
Also, sometimes the seal will wear a groove in the crankshaft, which may cause difficulties getting a leak proof seal, but you can get a repair sleeve from an auto parts store, which fits over the crankshaft. May want to check for that too, and maybe replace the front pump seal on your trans while it's out, if it's an automatic.
Old 10-17-2010, 06:20 PM
Old93junk's Avatar
Yes, forgot about the repair sleeve, you may need one if the old seal has dug a groove in the C-shaft. NAPA usually is a good source. The trans pump seal is good thought too, might as well while its down.
Old 10-17-2010, 07:15 PM
thanks for all the advice and tips
Replacing rear main seal 223 teardropty 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 08-04-2012 03:28 PM
'92 Bronco FS W/460 conversion rear main seal... NHWatchDog 1978 - 1996 Big Bronco 3 12-23-2011 09:09 PM
REAL MAIN SEAL REPAIR STOP LEAK robjs111 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 8 10-02-2011 10:28 AM
Rear main seal. BigBlue92 1987 - 1996 F150 & Larger F-Series Trucks 9 05-08-2011 05:57 PM
Rear main seal 1 or 2 piece? Zorfox 1987 - 1996 F150 & Larger F-Series Trucks 10 09-19-2010 06:31 AM
Tags
150, 1989, 1996, 1997, 2008, 93, change, changing, diesel, f250, ford, main, rear, seal, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
