View Poll Results: how many have a 2003 6.0 that shakes
fuel pump
0%
injector
100.00%
Voters: 2. You may not vote on this poll
Engine Shakes
Engine Shakes
I have a F250 2003 6.0 diesel. A couple of days ago I know my truck started shaking under throttle. I poured the diesel kleen to it, change the fuel filters, fuel pump, and changed the oil. The problem has diminished dramatically, now as the truck is going up through the gears(automatic) i can barely feel the shake, but when it goes into overdrive around 55-60 mph and the rpm's drop to around 1700 it still shakes. The shake gives you the same feel as a wheel coming loose. Need help.
Taking a shot in the dark, here, but I would think maybe a bad injector or two.
The HEUI injection system relies on oil pressure to fire the injectors, and new oil could affect the way the injectors fire.
The fact that the vibration lessened after you changed the oil points to a misfire, has it thrown any codes?
ALAN_50501
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
11-01-2015 05:44 AM
waystro
10-23-2011 08:25 PM
carolinaranger90
03-09-2011 05:05 AM
