fuel mix
We did that to our HMMWV's in Iraq and Afghanistan because the fuel quality there is poor and provided no lubricity that diesels require. It did solve some of our problems especially with the runaway engines, but we only used it because the army won't buy additives. I won't use it on my personal vehicle though, I use klean diesel. If your trying to go for a cheap additive to add lubricity, you may want to try ashless two stroke oil. Do a search for it there are plenty of guys that use it and swear by it.
on
That's just one thing I've never been on board with is additives. Fuel or oil additives. Statistically speaking as much as a travel I should have come across some "issues" that would have changed my mind, but either I've had Divine Intervention or the odds of really needing that in the areas that I travel are really low.
However, if I was to do it, I wouldn't use 2-stroke oil or trans fluid. That just doesn't seem right in my mind, moreso with the trans fluid.
Question how big is your tank. I have a 44galon tank and just wondering how much to put in ?
I do have to say that I am an advocate of the Motorcraft Cetane Booster. If you have not tried it I would say you should. I noticed a definite improvement in my truck when I started using it. My truck gained approx. 1 mi. per gallon and it seems to idle quieter (less injector "clack") while I am using it. Ever since about 3,000 mi. I've put it in at every fill-up (except a couple when I ran out or something) and I plan on sticking with it. I understand if you don't go for lots of "hype" because I'm the same way but I do believe this is worth it.
