Frozen Franks
Frozen Franks
I stumbled upon a good method for separating frozen hot dogs from each other
I made some pizza at home, and then I used my standard circular-blade pizza cutter to slice it up, the same one you see the pizza shop guys use.
Then I had the munchies for some hot dogs. I pulled out a 50 pack of frozen franks. I was wondering how I was going to hack the hotdogs apart, then I noticed the pizza cutter on my kitchen counter.The frozen franks are usually difficult to get apart, but with a pizza slicer you can easily separate the hotdogs by running the cutter between the frozen franks. The circular blade cuts the dogs apart nicely, it rolls right thru the icy bond and the hotdog pops right out of its place. Give it a shot and tell me if this a stroke of genius or what!!!
79modified
10-05-2005 12:18 AM
