Rear main seal intall
First, you will have to remove the old wear ring. Ford makes a tool to do this job, But, they are very proud of it!
Solution:
CAREFULLY, ping the wear ring on the flat side with a cold chisel, do this every inch or two around the crank, then carefully with a screwdriver or lady slipper, rock it back and forth and it should come off,
Installing the new ring:
Take four flywheel bolts with some spacers over the threads and a washer on each and carefully press the new ring on slowly. if it goes crooked very much it will get distorted.
Any more questions, just ask!
Solution:
I haven't had any problems...
halltm
04-13-2011 10:25 PM
holdendaniels
12-04-2010 08:51 PM
Six Niner
04-01-2008 07:42 AM
