Sticking fuel pump relay in cold weather? - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 02-24-2003, 11:08 AM
JBronco's Avatar
JBronco JBronco is offline
JBronco is starting off with a positive reputation.
1990 5.8 auto. My fuel pump did not want to shut off this morning, it was very cold, about minus 5 degrees. When I turned the truck off, the fuel pump kept running. I went under the hood and jiggled the wires marked "fuel pump," next to where you attach the code reader on the drivers side inner fender. This made it stop.
One more thing, the truck had a coolant leak this morning, it seemed to be from a hose clamp, so we tightened them all and sprayed the engine down to get the coolant off. Maybe water got into the relay and since it was so cold, it did not dry? Actually, is that the relay that I jiggled, and if so, is it replaceable?
Old 02-24-2003, 07:01 PM
BOJOFASO BOJOFASO is offline
BOJOFASO is starting off with a positive reputation.
hey jbronco
my 91 used to do the same thing. the relay would stick and the fuel pump would not shut off. yes it is replaceable. let me go outside and get the part number for the relay. E3TB9345A2A i think it was about 30 dollars. you dont have to go to ford but i did.it was a pain to get it un cliped from the mount. hasnt stuck since i changed it.
Old 02-24-2003, 07:03 PM
hey j bronco
how did you make out with the relay you were going to install last month?
Old 02-24-2003, 07:36 PM
JBronco's Avatar
Thanks. I will keep my eye on it and if it happens again I will replace the relay.
I never needed that relay, it turned out that a bad ignition switch was the source of my problems. But thanks for the tips. I kept the 70 amp relay that I special ordered from JC Whitney, you never know when you might need something like that and they are not available locally.
Old 02-25-2003, 07:31 PM
saanders saanders is offline
saanders is starting off with a positive reputation.
Do what BOJOFASO said and get the new relay. It fixed my '90 5.8L Bronco. I think they have a TSB on it, but I never ran across it.
Old 02-26-2003, 10:04 AM
JBronco's Avatar
This has not happened again, I think it just got wet/icy from when we hosed the engine down in the morning after fixing the leaky hose clamp.
Questions about replacing fuel pump 2FordTrucks Excursion - King of SUVs 8 01-24-2016 04:12 PM
Need Diagnostic Help! siciliannightmare Ford Inline Six, 200, 250, 4.9L / 300 7 09-10-2014 09:55 PM
4.2L Starts Randomly pcwb 3.8 & 4.2L V6 4 12-18-2013 01:54 AM
No ground from fuel pump relay to ECM. SiscoKid 1987 - 1996 F150 & Larger F-Series Trucks 6 07-09-2012 09:54 PM
Fuel pump (not relay - already checked) need PCM help drudis Explorer, Sport Trac, Mountaineer & Aviator 4 02-12-2010 12:34 PM
Tags
2003, bronco, cold, e3tb9345a2a, ford, fuel, location, operate, problem, problems, pump, relay, sticking, truck, weather
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
