maf sensor or not? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2014, 07:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
Print Wikipost
maf sensor or not?
Old 10-15-2010, 09:51 PM
Rick03F250's Avatar
Rick03F250 Rick03F250 is offline
Rick03F250 is starting off with a positive reputation.
Unhappy maf sensor or not?
On the way home from work, my engine started to lope, miss, and carry on like I got a bad tank of gas. (I did just fill up yesterday) Anyway like I was saying; every time I got heavy on the pedal it would act up. If I eased on it, it seemed to be ok, except climbing hills. Try pulling out into traffic moving around 55mph, and barely touching the gas with a manual trans. (Pretty tough)
Made it to a friends garage, no idiot lights came on, and no codes on his scanner. It did see that it ran rough around 2200-2500 rpm on the way there. searching thru all the fancy things on his scanner, he came up on the maf sensor and ran the test. (still no idiot lights or codes)
When excelerating slowly the numbers slowly climbed but when he got to around 2000+ rpm the #'s started to jump all around.
He said " there's your prob." kewl... only a maf sensor...huh $200 for a new one. had to order one knowone keeps them around I guess. Drive home taking it easy and now it dosent even want to idle smooth?????
What I'm getting at is should I go with the sensor or am I barking up the wrong tree?
Oh yeah I did just put a new k&n air filter in last week.
HELP!!!
Old 10-15-2010, 10:47 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
First, try a quick run without the K&N filter, but I doubt that is the problem.
My old F-150 acted the same way, complete with no codes. Turned out to be a clogged catalytic converter. Disconnect your exhaust at the Y-pipe and go for a quick spin to test.
Old 10-15-2010, 10:51 PM
Rick03F250's Avatar
Been thru the converter prob. already last year. It will never give me problems again. If you know what I mean.
Old 10-15-2010, 10:53 PM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
What engine?
I'd take the K&N off and put the stock intake back on, clean the MAF with MAF cleaner and see what happens, before I spent money on a new MAF.
Old 10-15-2010, 10:58 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Second name for "K&N" is "MAF killers"
One way to confirm bad MAF is to pull the plug on it. The engine should go into default mode, that should give you at least 80% of normal power.
Old 10-16-2010, 09:35 AM
Rick03F250's Avatar
5.4L ENGINE DC
It's all oem intake just a K&N filter in the oe can
Old 10-16-2010, 09:49 AM
FORDTUF1's Avatar
FORDTUF1 FORDTUF1 is offline
FORDTUF1 is gaining momentum as a positive member of FTE.
I have heard many people talk about the K&N's like that as well. I have run them since 1993 in every truck and minivan (yep, you just look for a car with the same engine and you get them perfectly fitted) and never had a problem.
The problem I have heard, and always avoided, was over-oiling of the filter. I did once get a new filter out of the box and thought is was too much oil. I put it in and checked the housing and sensor a few months later and it was indeed gumming the stuff up.
I cleaned the tubes/intake and I sprayed the sensor with contact cleaner and let it air dry, did not touch it with anything, worked great. I guess they have the MAF cleaner now since so many people were using the wrong stuff to clean it with, like parts cleaner.
Old 10-16-2010, 10:06 AM
few2many's Avatar
few2many few2many is offline
few2many is starting off with a positive reputation.
Quote:
What about brakleen or carb cleaner?
Old 10-16-2010, 11:22 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
ONLY USE MAF CLEANER. BrakeKleen and CarbCleaner will damage the plastic components.
Old 10-18-2010, 03:29 PM
Rick03F250's Avatar
Well... spent the $$, got a new sensor and put it in, still ran CRAPPY. Decided to disconnect the neg. bat. term. for a few min. to reset everything. Ran a little better.
wondered if it was bad gas? so I put some Lucas feul treatment in and brought it to work today. Not sure what it was but it startet to run better the more I ran it so.....?
We'll see on the way home.
Surging Idle 5.4L 1999 F250 jbalestri 1999 to 2016 Super Duty 6 06-24-2016 10:11 PM
2002 E250 5.4 starts out running fine, crawling in 10 minutes Ryan Simpson 1968-2013 Full Size Vans 15 04-12-2016 07:53 AM
1995 F-150 Code 173 & Poor Drivability omar1746 1987 - 1996 F150 & Larger F-Series Trucks 4 03-15-2016 09:43 PM
2000 F350 V10 P0171 and P0174 ? landyaght Modular V10 (6.8l) 3 11-16-2013 12:05 PM
4.0L poor acceleration devyn88 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 7 01-25-2011 12:45 PM
Tags
2002, 2003, 60, 73, air, bad, e150, f250, flow, ford, location, maf, mass, powerstroke, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
