intake gasket replacement questions - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 10-15-2010, 02:57 PM
flaredfx4 flaredfx4 is offline
flaredfx4 is starting off with a positive reputation.
I'm getting ready to replace the upper and lower intake gaskets on my 2001 3.0L due to a suspected vacuum leak and had a few questions. What other sensors or parts should also be changed when everything is off? At 135,000mi all that has been done that i'm sure of is a couple front coils, and the pcv rubber line. I do have a new coils in the garage so maybe I'll change the back ones. Any special instructions or tips for the gaskets? I didn't find any write-ups when I searched. Thanks
Old 10-16-2010, 08:43 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
It's fairly easy to do. I would replace the spark plugs in the back since that requires removing the upper half of the intake manifold too. If you have a good phone or digital camera take pictures so that you get everything back in the right place. It only takes about 2 hours (or less) to do. I got the gasket set at AZ for $8.
Old 10-16-2010, 09:21 AM
Sounds good, i'll tackle it on monday. Are the oem MC plugs what people usually go with, or is there a better option? I noticed some are replacing the ect sensor when the intake is off, is that necessary?
Old 10-29-2010, 03:28 AM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
heres a great how to.I like Motorcraft or Autolite plugs
http://www.ford-trucks.com/forums/45...ark-plugs.html
Intake manifold question..... Metrojd Modular V10 (6.8l) 6 02-18-2014 05:08 PM
Help with cold start & stutter husker3in4 Escape & Escape Hybrid 81 01-23-2014 07:17 PM
Intake/Exhaust Gasket Install CJ77F100 Ford Inline Six, 200, 250, 4.9L / 300 37 01-23-2011 11:22 AM
HELP 4.2 lower intake gasket leaks oil into intake cougar73 3.8 & 4.2L V6 3 10-06-2008 11:00 AM
Intake Manifold Install Marlboro L FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 05-02-2004 12:14 PM
Tags
2001, 2003, 30, change, escape, f150, ford, gasket, gaskets, intake, lower, mazda, replacement, sport, trac, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
