ecu code location
ecu code location
The code can be found in one of two places. On the inside of the drivers door near the front there will be a small tag with a 4 digit code. For exp. PMT3.
If you can't find it there them you will need to remove the ECU from under the dash, as it will be on a lable on the side of the box.
As for chip installation, Took me a bout 45 min, and that was taking my time to make sure I didn't have to go back and reclean the expansion port on the ECU.
Good Luck, hope this helps.
Will-
Will-
FTE Ken
Computer Chips & Tuners
01-30-2003 11:57 PM
redlead3
07-29-2002 12:58 PM
