Rebuilding the 6.0 VGTurbo
#47
#48
with that orientation of the turbine vertical it may leak oil from the seal because it's already toast and the seat is filled with coked up oil deposits.
You should remove the turbine to get to the three tx bolts so you can access the seal and replace it.
Once you have your new seal snapped into its seated position I think all your troubles will be over and you won't have to worry about it leaking any longer.
Happy Wrenching
Happy Wrenching
#49
Happy Wrenching
Happy Wrenching
If you cant close the gap enough to stop oil, that probably is where my issue is... It may not be a bad seal... Just the oil got to a level higher than the gap in the seal.....
In your writeup you write "install seal with gap orientated UP, that tells me that the oil (due to the large return line) shouldn't get any higher than that gap in the seal (unless there is a restriction).....
I'm just a backyard wrencher, this info is all what Ive gathered from FTE and various other Forums..... But I could still be wrong.....
Thanks again!!!!!!!!!!!!
#51
Well, just finished, it seem to have remove some play, may be .001mm, but it does not touch any part of the housing, so I will be reinstall and see.
The metal ring that provided in the kit that goes on the shaft did not have any V or U groove, so I just installed it.
Will run the thing tomorow, hopefully
#53
#54
#56
Brother BenchWench,
Out flipping standing demonstration and practical application rebuilding your turbo; A+, top shelf material. Twelve years since your posting, and I am benefiting by utilizing your tutorial . Good Mojo still coming your way. Thank you for taking the time. I am sure Diesel Tech Ron would fully approve your work.
Sincerely,
Greg
BrotherMan, bro-dawg
Sincerely,
Greg
