Bronco II Ford Bronco II
Biggest tire size info needed
Old 04-17-2004, 07:52 PM
Ken00's Avatar
Ken00
Ken00 is offline
It seems like we get a lot of questions on the biggest tire that will fit without rubbing so I would like to get a complete thread covering 2wd, 4wd and 4wd with a small lift, say 3-4". Thanks for the help.
Old 04-17-2004, 08:09 PM
Fully_Loaded's Avatar
Fully_Loaded
Fully_Loaded is offline
Go to www.4wheelparts.com they have a fitment guide and also have a gear ratio chart
Old 04-17-2004, 09:25 PM
jeeph8ter's Avatar
jeeph8ter
jeeph8ter is offline
I have a 2" body lift and 31" 10.50 BFG AT's on the stock rims. I had to cut out a small section of the fenders front and back for off-road use.
Old 04-17-2004, 11:41 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
I have 235/75R15's (approximately 29" X 9.50") on 7 or 7.5 in rims. They rub a little on the sway bar (when the sway bar is installed).
I've tried the 31X10.50's from my Explorer on my BII and they rubbed some, but could perhaps be tolerated if one was tolerant of such things.
Old 04-18-2004, 07:59 PM
TimmyAbrams's Avatar
TimmyAbrams
TimmyAbrams is offline
With no body lift, I run the 235/75r15. I tried the 31x10.5 from a friends F-150; however, when I tried a semi-sharp turn, they rubbed the fenderwells. I don't think that it's quite a smart idea to run them without a body lift.
Old 04-20-2004, 11:09 AM
Kallie's Avatar
Kallie
Kallie is offline
I have a 1990 Bronco II with 30's with out any rubbing and it is stock.
Kallie
Old 04-24-2004, 11:48 PM
CherryColaholic's Avatar
CherryColaholic
CherryColaholic is offline
I have an '89 4X4 with a 2 in lift on the back only.. i run 31 X 9.5's it rubs when the wheels are turned all the way. Also since i got new shocks that are a bit stiffer than the old ones i have been able to catch air without rubbing the inner wheel wells. But thats only if you land on two or more wheels at the same time. Out wheelin' i still get a rub here n there but its no big deal.
Old 04-25-2004, 02:37 PM
CherryColaholic
correction.. i have 31X10.5's my old tires were 30x9.5
Old 07-15-2004, 04:16 PM
Help I M Stuck's Avatar
Help I M Stuck
Help I M Stuck is offline
I've got a 86 BII with 3 inch body lift, 4inch SkyJacker lift and 35 X 12.50 X 15 BFG A/T's and have no problem.
Old 07-28-2004, 12:50 AM
'87BroncoII's Avatar
'87BroncoII
'87BroncoII is offline
30X9.5 is what i got on my stock 87 BII the people at the tire store refused to even try to put 31x10.5 stock they were like now way apparently they dont want my money eh
Old 09-12-2004, 09:26 PM
Kevin86Bronco's Avatar
Kevin86Bronco
Kevin86Bronco is offline
So wait what can I fit without having to get an lift. I dont want to lift the truck but I want a little bigger tire then I have.
Thanks!
Old 09-12-2004, 11:36 PM
RomerB2's Avatar
RomerB2
RomerB2 is offline
i have 265/75/15's on mine w/ no lift, its 4WD and i have no rubbing, even if i turn all the way there's nothing, i have stock rims, fixing to get 31's with 4' lift, and i think it would fit even for offroading, but i've found a way to do a 6 inch lift and if i do that then im gonna go for 33's
Old 09-13-2004, 06:21 AM
Kevin86Bronco
Are these something I can get over at Firestone or town fair tire?
Old 09-13-2004, 05:41 PM
Bronco2Nic's Avatar
Bronco2Nic
Bronco2Nic is offline
I have a stock 1985 BII and I am running 235/75R15s with no rubbing.
Old 09-14-2004, 12:29 AM
RomerB2's Avatar
RomerB2
RomerB2 is offline
these being the tire sizes we've listed? Most tire retail chains go up to about a 265/75 w/ various rim sizes, some only go up to a 235 or so, 31's you can find at some tire retailers, and sometimes you can find 33's 35's and 38's, but most likely your're gonna get 235's or 265 as limit in height, it depends on the reatailer, i've never dealt with firestone, i'd go with BF Goodrich if you're wanting something that looks pretty good at a decent price, or go with Bridgetsone Dueller's they're nice too, and come in some bigger sizes
Quick Reply: Biggest tire size info needed
