85 I6 300 carbed - smog delete help please
Picked up an 85 f150 4wd truck. truck is tight but alot of the smog was removed. don't need smog here. I would like to get rid of the rest of the smog and have a good running truck. This is what i know about it. The guy i got it from had a rblt carb put on and it never ran rite after that. The one they put on has no electrical connector don't know what came off. The intake @ ext gaskets are shot so is the valve cover so i'm replaceing them now and would like to get rid of the rest of the smog on a tight budget.
MISSING - smog air pump , stock air cleaner , cat converter , and probably a lot more. A lot of plugged air / vac lines, wires going no ware.
there are 3 vac solenoids on the back of the valve cover with wires going to them . The dist has all wires no vac advance. EGR has large tube from ext manifold can i get rid of it and egr?
A friend has a dist with a vac advance and a electrical box he said should do it.
any help would be to cool or point me in the rite direction. thanks
You're doing a conversion from TFI ignition and feedback carb to DSII ignition and pre-feedback carb. Changing your truck is a violation of Federal Law except for off road only use.
To do the off road use conversion, you'll need the distributer, ignition module, coil, coil wire, and wiring harness from the left fenderwell to the distributer(it comes off as a unit), and depending on the carb you have, the carb.
This thread
https://www.ford-trucks.com/forums/9...-86-i-6-a.html
and this search will help.
Ford Truck Enthusiasts Forums - Search Results
Let us know how you're doing, and post more questions when you have them.
This thread
Thanks Frank for the help. this truck will stay on my 40 as a farm truck so i don't keep beating up my 03 I6 Cummings 3500 another great 6. after reading the posts ideally 80-83 parts would be best rite ?. carb has no electrical connections on it is it a feedback carb ? what to do with EGR sys?. thanks again Derrick
You'll need to connect the 12V lead to the alternator field connection, and once you have the harness from the 80-83 in place, you can pull the computer out from under the dash and pull the snake of wires through the hole in the firewall as well.
on
Some of the EGR valves are computer controlled, using EGR solenoids.
He needs to get one that is calibrated correctly. There are over 100 different ones for the 300 between 1980-1983. Aftermarket EGR valves use seperate washers to calibrate them that you have to press or punch in, to get the number of valves down to a few.
There are a few computer controlled MCU - DS-II hybrids out there that you need to stay away from. These have a DS-II with feedback carb, and a EGR solenoid controlling timing from the MCU. The distributors vacuum advance is also different and has ported manifold vacuum to the vaccum advance at all times. The computer bleeds off vacuum to retard timing when needed. Vacuum advance works normally otherwise. These are also timed at 6 degrees instead of the normal 10 degrees due to the constant vacumm signal to the advance at idle.
These were found sporadiclly between 1981-1983. Why 1980 would be best to look at. F-350 because these had very little smog on them at all.
They also had different carb calibrations between automatic and standard transmission.
All these things need to work together correctly.
The EGR for the 83 nwill work fine as well, but why not leave the one he's got in situ and see if it works right? It might, mine does. It's best not to disable it completely.
I haven't ever seen the DS II hybryd- thanks for sharing. Do you have pics? I'd be curious to see it.
on
Here you go...
1981 with MCU and DS-II: typical california, AND some high altitude models. 1981-1983.
1981 control solenoids.
The carb from a 1971 will not bolt directly on without modification, due to mating differences in the intakes.
As I said before there are different calibrations for Manual and Automatic transmissions to be aware of as well as different smog calibrations. match tranny for tranny so to speak.
Here you go...
And agreed, make sure you get the right carb for the tranny you've got.
Thanks for the photos- I never knew. Looks like something CA would require, doesn't it?
I found these parts from a 79 i6 "harness , dist , box with blue insulator , coil " Will they plug and play or what will i have to do to make them work. Not real sure about the 12v alternator field connection thanks in advance.
For the harness i got a 79 the plugs aren't rite. one square and one round . You say a harness from a 80-86 351 ho or 460 will be the same as 83 I6 harness. how to tell if 351 is ho or not?
can't seem to upload any pics or forgot how. thanks
Also, the 351 HO will have a 4bbl carb.
