UPFITTER SWITCHES WHAT'S HOOKED TO YOURS? - Ford Truck Enthusiasts Forums
Old 10-14-2010, 07:45 PM
11superduty 11superduty is offline
11superduty is starting off with a positive reputation.
Question UPFITTER SWITCHES WHAT'S HOOKED TO YOURS?
What your upfitter switches hooked to? I'm going to hook one of mine to a light in my cap, now I'm looking for place's for the other three any good idea's????
Old 10-14-2010, 07:52 PM
fz1dave's Avatar
fz1dave fz1dave is offline
Super Duty
fz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud offz1dave has much to be proud of
Radar detector & satellite radio. 2 to go.
Old 10-14-2010, 08:00 PM
Thom12's Avatar
Thom12 Thom12 is offline
Thom12 has a good reputation on FTE.Thom12 has a good reputation on FTE.Thom12 has a good reputation on FTE.
I am only using one right now, for my onboard air compressor. Have my whole truck piped for air, even a place to hook in a hose for airing up my 5th wheel tires if needed.
Plan to use a second on for a larger capacity 110 V inverter.
Old 10-14-2010, 08:37 PM
Nipperdog's Avatar
Nipperdog Nipperdog is offline
Nipperdog is gaining momentum as a positive member of FTE.
A vibrating bed, and an expresso machine LOL
Old 10-14-2010, 08:48 PM
Quote:
Wow my dealer told me when I ordered my truck "you will have everything but a coffee maker" maybe I will have a coffee maker switch #2
Old 10-14-2010, 09:40 PM
deedsF350 deedsF350 is offline
deedsF350 is starting off with a positive reputation.
how big of a tank do u got for ur air compressor and dose it take a while to pump up i would like to put one on my truck but dont no what is a good one that will last
Old 10-15-2010, 12:32 AM
RickSo's Avatar
RickSo RickSo is offline
RickSo is starting off with a positive reputation.
I used switch #3 for a radar detector (Escort 9500ix) ran wire in headliner down driver side post to upfitter wire. I was going to use a switch for refueling tank in back but used OE switch because of the purge feature which reverses pump to drain hose back in tank.
Rick
Old 10-15-2010, 07:26 AM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
#1 - on/off ignition source for subwoofer amp
#2 - VIAIR #10007 Onboard air system
#3 - blank
#4 - strobe lights
The Viair system is really nice so if anybody is shopping around, give Viair a look. They have lots of configurations available.
Old 10-15-2010, 08:32 AM
Thom12's Avatar
Quote:
I use the Viair 1007 kit that ruschejj talks about. I believe he has pictures posted some where of his set up. My set up I put my gauges on the overhead console. The specs for the viair are available on several websites. Works for everything I have tried so far. The kit 1007 comes with a 2.5 gallon tank.
Old 10-15-2010, 08:38 AM
machine62's Avatar
machine62 machine62 is offline
machine62 is starting off with a positive reputation.
Rick, I'm curious about the radar detector hookup. Did you find a different (longer) cord that lets you hardwire it to a power source? I have an escort as well and that sounds like a really good idea.
Old 10-15-2010, 01:55 PM
11350KINGRANCH's Avatar
11350KINGRANCH 11350KINGRANCH is offline
11350KINGRANCH is starting off with a positive reputation.
1: 6 90w strobe lights and 2 blue Led's in the grill
2: police siren
3: empty
4: Viair constant duty compressor (put mine in the tool box)
Old 10-15-2010, 03:35 PM
RickSo's Avatar
Quote:
I just bought the direct wire cord from my local dealer that sells Escort and ran the wire in the headliner and down the post to the #3 upfitter wire.
https://www.escortradar.com/store/direct-wire-cord.html
Rick
Old 12-23-2011, 03:04 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Rick,
Do you just hook the positive wire to the Upfitter wire? Where you hook the Ground (Negative)?
Old 12-23-2011, 04:00 PM
lakedweller's Avatar
lakedweller lakedweller is offline
lakedweller is starting off with a positive reputation.
nuttin.......
Old 12-23-2011, 04:39 PM
diesel smoke's Avatar
diesel smoke diesel smoke is offline
diesel smoke is starting off with a positive reputation.
100 amp remote mount relay for accessories off the rear (Lift Gate, Winch for flat bed trailer, Electric HPU for Dump trailer)
Plow and rechargable maglite
work lites on headache rack and rear bumper area
1 empty
these are great options for a truck
What accessories do you hook to upfitter switch? farmcotton 2017 Super Duty 24 12-01-2016 08:27 AM
What is Hooked up to Your Upfitters? DCP 1999 to 2016 Super Duty 7 09-26-2013 10:28 AM
What is hooked to your upfitter switches? scrdanis 6.0L Power Stroke Diesel 6 02-20-2011 08:09 PM
Upfitter Switch Wires DIXIEDOG1 1999 to 2016 Super Duty 4 07-04-2010 04:51 PM
Upfitter switches Froglips 1999 to 2016 Super Duty 17 09-14-2008 09:23 PM
Tags
110, 2010, constant, escort, f150, f250, fitter, ford, hardwire, hook, ignition, outlet, powerstroke, radar, switches, upfitter, volt, whats, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
