UPFITTER SWITCHES WHAT'S HOOKED TO YOURS? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-13-2013, 08:49 PM
kper05's Avatar
kper05 kper05 is offline
kper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant futurekper05 has a brilliant future
1 - LED bed rail lights
2 - KC rear bumper lights
3 -
4 - SEIC
  #47
Old 01-13-2013, 09:06 PM
Fontana Fontana is offline
Fontana is gaining momentum as a positive member of FTE.Fontana is gaining momentum as a positive member of FTE.
#1 - PIA high beam lights
#2 - front bumper camera
3 & 4 are not used yet
2011_F-250_ForestGreen's Library | Photobucket
  #48
Old 01-14-2013, 10:58 AM
TexasA&M's Avatar
TexasA&M TexasA&M is offline
TexasA&M is gaining momentum as a positive member of FTE.TexasA&M is gaining momentum as a positive member of FTE.
#1 - KC lights on front
#2 - Rear lights for hooking up to trailers
#3 - Viair on board air/air horns (regular horn sounds when switch is off)
#4 - high idle mod
  #49
Old 01-14-2013, 03:59 PM
Branden Wilson Branden Wilson is offline
Branden Wilson is starting off with a positive reputation.
anyone know if these can be added to an 2001 f350
  #50
Old 01-14-2013, 08:02 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Quote:
Originally Posted by Hopeless Diamond View Post
Doesn't it show up on your dash screen to shut it off whenever you put it in reverse? (had to listen to it numerous times before I figured it out that it's right there everytime)
It does but every time you start the truck, you have to shut them off, it'd be nice if when pulling a trailer to be able to shut them off all the time, hence the switch.
  #51
Old 01-14-2013, 08:03 PM
madsonp's Avatar
Quote:
From what I can tell, no.
  #52
Old 01-14-2013, 08:11 PM
kper05's Avatar
You may want to search and then ask the folks in the 7.3L section.
1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
This guy added to his 2002 but it looks like he replaced his lower dash with a 2005 so the '05 upfitters would install.
http://www.ford-trucks.com/forums/95...fo-needed.html
I didn't find any info in the tech section either so I'm with madsonp, doesn't look like the info is easily found but I also didn't own a 2001 either.
http://www.ford-trucks.com/forums/11...l#post12172295
  #53
Old 01-14-2013, 08:25 PM
thanks guys I will look in to it and let you know what I find out or do
  #54
Old 01-15-2013, 06:03 AM
Adobe 11SD's Avatar
Adobe 11SD Adobe 11SD is offline
Adobe 11SD is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by madsonp View Post
How did you do the reverse sensor override?
I had the dealer install an aftermarket Advent system, so I'm not sure how the factory system is wired.
After fooling around with the "mute" circuit I finally figured out all I needed to do was to install a 24VDC realy and wire one of the speaker wires to the Normally Closed contact.
Also need to note that I did not want to drive around with the upfitter on 95% of the time, just wanted it on when in "override" -- this allows me to have all of the switches in the same position for normal operation. If you choose to use the Normally Open contact, your switch will be in the opposite postion for normal operation.
  #55
Old 01-15-2013, 06:27 AM
Adobe 11SD's Avatar
No, I had the dealer install an aftermarket system with a physical mute button.
The issue is that when pulling my boat the alarm constantly beeps every time I put the truck in reverse.
Especially frustrating when trying to get into tight places at the ramp or when I am in the boat (on the trailer) and someone else is backing down the ramp to launch the boat or parking the trailer after the boat is in the water.
  #56
Old 01-15-2013, 10:25 AM
ggadwa ggadwa is offline
ggadwa is gaining momentum as a positive member of FTE.
Up Fitter Switches
Randy,
Darn, I was hoping you knew the trick to wire a bypass to the Upfitter switches for that Darn Reverse Alarm......I am really tired of resetting the alarm to OFF every single time I want back up the truck with Camper or Toy Hauler Trailer.
Anyone else figure out how to Put a Reverse Alarm Bypass on an upfitter Switch????
GARY
  #57
Old 03-29-2013, 02:31 AM
GCG's Avatar
GCG GCG is offline
GCG is starting off with a positive reputation.
train horn switch
Quote:
Originally Posted by Tethergrain View Post
1. extra set of OEM fogs
2. maximus train horn switch
3. TBD
4. TBD
Tethergrain,
Which kit did you go with? How does the horn activate if wired to the upfitter switch?
  #58
Old 03-30-2013, 05:44 AM
Munfrobie Munfrobie is offline
Munfrobie is starting off with a positive reputation.
With a trailer plugged in my reverse alarm does not sound ever. What am I missing in this post? Is it a setting you need to apply that maybe I did?
  #59
Old 03-30-2013, 07:26 AM
mrjc's Avatar
mrjc mrjc is offline
mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.mrjc has a good reputation on FTE.
#3 in-bed camera looking at the 5th wh. hitch
#4 The hitch slider motor
Adding some cameras to 1 and 2 or High Idle or Hot tub. So many choices, so little money
  #60
Old 03-30-2013, 07:56 AM
U235Fishin' U235Fishin' is offline
U235Fishin' has a good reputation on FTE.U235Fishin' has a good reputation on FTE.
Backup Alarm
My truck came fitted with a backup alarm. I want to avoid irritating my neighbors at 6am when I back out of the garage, but I still use it in tight places like parking lots. Air bags in the future.
#1-nothing yet
#2-nothing yet
#3-backup alarm
#4-nothing yet
Upfitter safety switch or lockout? Piolet 1999 to 2016 Super Duty 19 02-09-2017 04:40 PM
What accessories do you hook to upfitter switch? farmcotton 2017 Super Duty 24 12-01-2016 07:27 AM
Rigid light install question for upfitter switch Wizness 6.7L Power Stroke Diesel 13 01-18-2014 12:58 PM
What is Hooked up to Your Upfitters? DCP 1999 to 2016 Super Duty 7 09-26-2013 09:28 AM
What is hooked to your upfitter switches? scrdanis 6.0L Power Stroke Diesel 6 02-20-2011 07:09 PM
Tags
110, 2010, constant, escort, f150, f250, fitter, ford, hardwire, hook, ignition, outlet, powerstroke, radar, switches, upfitter, volt, whats, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
