UPFITTER SWITCHES WHAT'S HOOKED TO YOURS? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-31-2012, 11:14 AM
porthole's Avatar
porthole porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
#1 50 watt 2-way radio
#2 -
#3 High idle
#4 air compressor
  #32
Old 12-31-2012, 11:51 AM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
Quote:
Originally Posted by DutchBlackie View Post
#1 = 2 * 8" KC distance lights (inner 2)
#2 = 2 * 8" KC distance lights (outer 2)
#3 = 2 * Rigid Industries Dually Series Clear Flood Light
#4 = Vacant (15amp fuse canabalized for fuse 30 = taillights)
#5 = rear fog light (mandatory in Europe)
#6 = WirelessAir system
Six switches??
  #33
Old 01-01-2013, 11:20 PM
fatheadon1's Avatar
fatheadon1 fatheadon1 is offline
fatheadon1 is starting off with a positive reputation.
in my 2012
1 rigid 20 led bar in bumper
2 air compressor/snowplow salter power
3 strobes
4 led reverse lights mounted under the bumper on the trailer hitch
on my 05
1 transfer tank pump
2 High idle/snowplow salter power
3 strobes
i need more switches in both
  #34
Old 01-03-2013, 03:51 AM
DutchBlackie's Avatar
DutchBlackie DutchBlackie is offline
DutchBlackie is starting off with a positive reputation.
Yep, I needed two switches which need to be always hot so I installed two more.
Quote:
Originally Posted by RM2738 View Post
Six switches??
  #35
Old 01-13-2013, 07:51 AM
2012F250SUPERDUTY4X4's Avatar
2012F250SUPERDUTY4X4 2012F250SUPERDUTY4X4 is offline
2012F250SUPERDUTY4X4 is gaining momentum as a positive member of FTE.
I'm using mines for:
1 - Nothing
2 - Nothing
3 - Nothing
4 - Nothing
Yet.
  #36
Old 01-13-2013, 08:44 AM
gsxr1300 gsxr1300 is offline
gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.gsxr1300 has a very good reputation on FTE.
Quote:
1 - Nothing
2 - Nothing
3 - Nothing
4 - Nothing
Yet.
Exactly same as mine!
  #37
Old 01-13-2013, 10:15 AM
Adobe 11SD's Avatar
Adobe 11SD Adobe 11SD is offline
Adobe 11SD is gaining momentum as a positive member of FTE.
Just installed mine a few weeks ago.
1- Nothing
2- Nothing
3- Reverse sensor override (stop from beeping when trailer is attached)
4- Back Up Lights
  #38
Old 01-13-2013, 11:44 AM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Quote:
1- Nothing
2- Nothing
4- Back Up Lights
How did you do the reverse sensor override?
  #39
Old 01-13-2013, 12:02 PM
SavageNFS's Avatar
SavageNFS SavageNFS is offline
not a WHITE truck
SavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputationSavageNFS has a superb reputation
1-Ejector seat (plan on switching that a high idle)
2-nothing yet (driving lights planned)
3-Reverse Aux lights
4-Air compressor
  #40
Old 01-13-2013, 01:26 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
1 - high idle
2 - light bar main power
3 - interior lights
4 - cargo light
  #41
Old 01-13-2013, 05:49 PM
madsonp's Avatar
1. nothing
2. nothing
3. nothing
4. nothing
But they look cool though
  #42
Old 01-13-2013, 06:19 PM
welbo97's Avatar
welbo97 welbo97 is offline
welbo97 is starting off with a positive reputation.
subscribing. I want to know more about air compressors and high idle.
  #43
Old 01-13-2013, 06:36 PM
SavageNFS's Avatar
not a WHITE truck
Quote:
Click link below for high idle mod...
http://www.ford-trucks.com/forums/10...ml#post9494561
The air compressor is for my airbags...it is just the power for the compressor. Some guys run auxiliary air for air horns, air tools or inflating tires. I run an auxiliary compressor on my 4 wheeler trailer so I only need the small compressor for my airbags.
  #44
Old 01-13-2013, 09:41 PM
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond is starting off with a positive reputation.
Doesn't it show up on your dash screen to shut it off whenever you put it in reverse? (had to listen to it numerous times before I figured it out that it's right there everytime)
  #45
Old 01-13-2013, 09:45 PM
fougazi fougazi is offline
fougazi is starting off with a positive reputation.
upfitters
Just finished wiring all of mine up today,
#1- work lights on headache rack
#2- nothing yet ( high idle in the future)
#3- driver side seat heater
#4- pass. seat heater
What accessories do you hook to upfitter switch? farmcotton 2017 Super Duty 24 12-01-2016 08:27 AM
What is Hooked up to Your Upfitters? DCP 1999 to 2016 Super Duty 7 09-26-2013 10:28 AM
What is hooked to your upfitter switches? scrdanis 6.0L Power Stroke Diesel 6 02-20-2011 08:09 PM
Upfitter Switch Wires DIXIEDOG1 1999 to 2016 Super Duty 4 07-04-2010 04:51 PM
Upfitter switches Froglips 1999 to 2016 Super Duty 17 09-14-2008 09:23 PM
Tags
110, 2010, constant, escort, f150, f250, fitter, ford, hardwire, hook, ignition, outlet, powerstroke, radar, switches, upfitter, volt, whats, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
