UPFITTER SWITCHES WHAT'S HOOKED TO YOURS? - Page 2 - Ford Truck Enthusiasts Forums
Old 12-23-2011, 05:57 PM
darren32's Avatar
darren32 darren32 is offline
darren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputationdarren32 has a superb reputation
1 = 2 8" KC driving lights
2 = 2 8" KC distance lights
3 = high idle
4 = heated wipers (soon, got em just not hooked up yet.
I wish the upfitters and trailer brake swapped spots. My short arms can't reach them without bending forward and I am always switching the KC on and off.
Thanks
Old 12-23-2011, 06:16 PM
Andrew010's Avatar
Andrew010 Andrew010 is offline
Andrew010 has a good reputation on FTE.Andrew010 has a good reputation on FTE.
high idle, interior dome light, rear cargo light. 1 empty.
Old 12-23-2011, 06:44 PM
Mikeyc187 Mikeyc187 is offline
Mikeyc187 is starting off with a positive reputation.
1: Mini Justice light bar
2: Fog lights
3: Blank
4: High Idle
Old 12-23-2011, 08:57 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
I never hooked anything up to my upfitters. I pulled out my upfitter panel and replaced it. I have 4 on/off toggle switches and a momentary DPDT toggle. The on/off toggles control (right now) - the bed lights, a becon light (outlet, plug the light in if I use it) and theres 2 open switches. The DPDT is my antenna's motor drive for remote tuning. Up raises the antenna (drops the frequency) and down drops the antenna (raises the frequency). I also have a microphone jack and a key jack all on the same panel.
You cant get all that on a standard upfitter panel
Old 12-23-2011, 09:04 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
What's with the sheets on your seats?
Old 12-23-2011, 10:07 PM
mach8274's Avatar
mach8274 mach8274 is offline
mach8274 is gaining momentum as a positive member of FTE.mach8274 is gaining momentum as a positive member of FTE.
#1-130w KC driving lights
#2-blank for now, reserved for onboard air system
#3-headrest DVD players
#4-auxiliary back up lights
Old 12-24-2011, 12:49 PM
PITS's Avatar
PITS PITS is offline
PITS is gaining momentum as a positive member of FTE.PITS is gaining momentum as a positive member of FTE.
1. Machine Guns
2. Smoke Screen
3. Oil Slick
4. Surface to Air Missles
Old 12-24-2011, 05:59 PM
'08FX4's Avatar
'08FX4 '08FX4 is offline
'08FX4 is starting off with a positive reputation.
Quote:
Originally Posted by P.I.T.S. View Post
1. Machine Guns
2. Smoke Screen
3. Oil Slick
lmao
1) Rear Floods Top pair (mounted on Back Rack)-use 'em when I'm plowing sometimes
2) Rear Spots Bottom pair (Mounted on Back Rack)- use them to help people remember to dim their high beams while driving behind me.
3) High/Low brightness switch for Strobes
4) Strobe Power on/off
Old 12-25-2011, 02:13 PM
kluger's Avatar
kluger kluger is offline
kluger is gaining momentum as a positive member of FTE.
So far only using #3 for Wiper Shakers. Plan to add more rear lighting and remote camera for trailer eventually on a couple more of the switches.
Old 12-25-2011, 02:52 PM
KC8QVO's Avatar
Quote:
I have a real hard time keeping the seats nice. I've already damaged them a bit in a few places. The covers keep abrasion and crap off the leather. I like the leather but I'd rather keep the covers on there every day and avoid screwing up the leather.
Old 12-25-2011, 03:15 PM
Rick Cargo's Avatar
Rick Cargo Rick Cargo is offline
Rick Cargo is gaining momentum as a positive member of FTE.
#1 blank, #2 blank, #3 Radar Detector, and #4 goes to the set of 110 watt back up/campground lights.
Old 12-25-2011, 03:44 PM
TRENT310's Avatar
TRENT310 TRENT310 is offline
TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.TRENT310 has a spectacular reputation.
I'm trying to find a worthy cause for #1 so it doesn't feel like I'm running out of switches already. Or I guess if it comes down to it, #2 can be moved to an ACC-ON line.
I'm kinda thinking of one or two amber strobe lights when I build that headache rack.
  #28
Old 12-28-2011, 12:03 PM
Tethergrain's Avatar
Tethergrain Tethergrain is offline
Tethergrain is starting off with a positive reputation.
switches eh?
1. extra set of OEM fogs
2. maximus train horn switch
3. TBD
4. TBD
  #29
Old 12-27-2012, 12:16 PM
PSDVirgil's Avatar
PSDVirgil PSDVirgil is offline
PSDVirgil is starting off with a positive reputation.
A disco ball, a frozen drink machine, and whirlpool pump. (Whirlpool in back of truck on weekends.) The remote "drive-while-hot tubbing" kit is still in development.
  #30
Old 12-27-2012, 02:54 PM
DutchBlackie's Avatar
DutchBlackie DutchBlackie is offline
DutchBlackie is starting off with a positive reputation.
#1 = 2 * 8" KC distance lights (inner 2)
#2 = 2 * 8" KC distance lights (outer 2)
#3 = 2 * Rigid Industries Dually Series Clear Flood Light
#4 = Vacant (15amp fuse canabalized for fuse 30 = taillights)
#5 = rear fog light (mandatory in Europe)
#6 = WirelessAir system
Upfitter safety switch or lockout? Piolet 1999 to 2016 Super Duty 19 02-09-2017 05:40 PM
What accessories do you hook to upfitter switch? farmcotton 2017 Super Duty 24 12-01-2016 08:27 AM
Rigid light install question for upfitter switch Wizness 6.7L Power Stroke Diesel 13 01-18-2014 01:58 PM
What is Hooked up to Your Upfitters? DCP 1999 to 2016 Super Duty 7 09-26-2013 10:28 AM
installing rigid light bar dieselsmoker 6.4L Power Stroke Diesel 1 05-11-2013 07:22 AM
Tags
110, 2010, constant, escort, f150, f250, fitter, ford, hardwire, hook, ignition, outlet, powerstroke, radar, switches, upfitter, volt, whats, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
