NO Vent air, JUST DEFROST! - Page 2 - Ford Truck Enthusiasts Forums
Old 04-21-2004, 04:28 PM
jason86's Avatar
jason86 jason86 is offline
jason86 is starting off with a positive reputation.
Quote:
Originally Posted by StreetGlowF-150
I think maybe its your selector motor. (couldent be really positive) having the same problem i can change my vent to blow cold or hot air or what speed i want it to come out but cant change off of defroster. There is a control motor back in the dash it would require taking the dash out but i think if you change that you'll be free to select the output.
Have you changed this motor on yours? What yr do you have? THanks
Old 07-22-2014, 06:06 PM
Stephen Mcmichael Stephen Mcmichael is offline
Stephen Mcmichael is starting off with a positive reputation.
ac
I have a 2000 fi50 and my ac only blows out the floor and defrost driving me nuts any ideas
Old 04-15-2015, 01:21 PM
PRIMERED79 SHORT BED PRIMERED79 SHORT BED is offline
PRIMERED79 SHORT BED is starting off with a positive reputation.
Old thread I know, did anybody find a fix for this?
I noticed mine has been doing the same, blowing only out of the defrost.
Old 04-15-2015, 06:06 PM
Found my issue.
The vacuum box near the fire wall on the passenger side has a crack on the bottom.
Bypassed it and all the controls work now.
Old 04-15-2015, 07:28 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
Originally Posted by PRIMERED79 SHORT BED View Post
Found my issue.
Good deal. If you find the HVAC switching back to Defrost under load again you may need to repair that small reservoir or make one.
Old 04-15-2015, 07:48 PM
rla2005's Avatar
Double post
Old 04-15-2015, 09:10 PM
I tied it into the vacuum can on the fender, seems to work good.
Panel Vents and Defroster turnkyle 1987 - 1996 F150 & Larger F-Series Trucks 12 02-01-2014 06:57 PM
Help me! A/C acting wacky wgm114 1999 to 2016 Super Duty 5 08-06-2012 07:04 AM
2003 f250 6.0 diesel a/c problem claycomotrucks1991 Cooling, Heating, Ventilation & A/C 22 05-29-2009 12:02 PM
A/C problem on 2003 f250 diesel claycomotrucks1991 6.0L Power Stroke Diesel 26 05-27-2009 08:04 PM
defroster problems on my bronco rafe1269 1978 - 1996 Big Bronco 13 11-01-2005 09:49 PM
Tags
1992, 1995, 2004, ac, air, change, control, defrost, e150, f150, f350, ford, ranger, stuck, vents
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
