Intermittent Bad Idle
Okay here it is. I have a 95 Powerstroke. Since I bought it it has had a rough idle and occasionally at a stop light after I've come to a stop it will sit and stumble so hard you swear it is going to die. I kick the throttle a little and it smooths out to the regular rough idle. Once I break off of idle it runs perfect pulls great is the best truck ever. I replaced the old crappy fuel filter housing with one off of a 97 thanks to a mechanic at work that sucks at diagnosing it was free lucky me. I've put a new California pressure regulator and resealed the ICP. With the ICP out I tested the solenoid and every time I put power to it it would pick up a screwdriver with little effort. What now??? No codes ever. I've unplugged the IPR and the engine doesn't change. I unplug the ICP and it dies. IDM? Any incite would be great. Oh and it does it anywhere during the oil change cycle with delo valvoline blue and rottela.
Yeah I did get the ICP IPR thing mixed up. It does get a little worse as the truck warms up but it is especially bad when I pull. Can injector o-rings cause this problem. It is so inconsistent and the truck runs so good off idle that I'm flat stumped. I resealed the IPR. If I unplug the IPR and the truck dies I unplug the ICP and nothing changes. The fuel pressure regulator I got from ford was for a 96 with California emissions it was a hundred dollars cheaper than the non cali and runs higher pressure. I can't believe how much more throttle response I've got now.
This sounds alot like what mine does...from previous discussions it was concluded it was probably o-rings. I've ordered a set and will change them out in the next few weeks. I'm hoping....
When at idle if I very slowly rev up I can feel a slight miss.
If I mat it (in neutral) it will rev up to 2500, then hesitate, then the rest of the way to 3k.
On the highway, it seems fine.
I haven't tried unpluging the ICP or IPR, because the miss is so subtle when it's idling good.
