High Idol Set Up Question
I have been thinking about doing the high idol mod for a while now. I am curious on one thing. I use water trucks quite often when i build tracks. I have used several F-550s and so on that have the high idol built in. Heres how it works......
1. put in netural
2. apply parking brake
3. apply gas pedal to reach designated rpm range
4. turn cruse control on and set
5. let off gas pedal and it will stay at the rpm range selected
6. from here you can accell or decell using the cruse paddles on the wheel
7. select off or tap brake pedal the shut the idol off
I know thats alot but just how it works. Im curious if anyone has done the high idol this way or if you can. To me seems like there must be a sensor or something that only allows the cruze to work in drive and going over 30mph. If there is a way to bypass the sensor allowing the cruse to work in netural at 0mph it should work in theory. I just dont know too much on this topic and if this is something that i could make work because obviously it dose work on the f-550 water trucks with auto trans.
Anything helps i just think this would be a awesome trick todo instead of a switch or **** set-up
1. put in netural
I don't know about the larger trucks but I have an '02 F350 and I put an aux idle control on it. It is a relay logic device. Two relays, a dash panel switch to activate it and a reostat I bought from radio shack. The wires are tied in to the foot pedal reostat and the E-Brake on the other end. The E-brake has a switch incorporated in to it to illuminate the dash brake warning light. The relays go to ground through the E-Brake switch. To operate it you have to set the E-Brake, turn the dash switch to on and then rotate the reostat up 'till the engine is at the desired speed.
My cruise control does not work below 30 MPH road speed.
From what little I have read about a 550 is that they have a somewhat unique PCM. It has to be the PCM that allows the use of the CC for adjustible high idle in the absence of an APCM. The problem for making this work in a 250 or a 350 would be getting a 550 PCM that would be compatible and including the 550 PCM wiring harness. I'm just thinking off the top of my head.
Edit : What year 550s are those water trucks, are they 7.3s, auto or manual?
The psd watertrucks were 7.3s. I know this just due to sound dident really pay attention to the year. Both i have driven have auto and manual trans.
I do see were you are coming from on the PCM stuff. Although i do think if you could by-pass some things you could make it work in theory. I just have no idea where to start.
With my luck, and never knowing when to quit until it's too late, I would go through three PCMs before I quit trying.
I have a high idle tune, but it would be nice to have an adjustable rpm high idle is what we're getting at, without installing an APCM.
But there is nothing to prevent getting a couple of high idle tunes set at different rpms.
I've got the pronunciation down but don't ask me to use it in a sentence.
Are you using multisyllabic words just to confuse us.
Remember, I'm the kinda guy who couldn't spell cat if you spotted me the k.
The cruise on an '02 uses the ABS circuit (tone rings) for speed calculation. SO, I am not sure how the F-550's are set up, but I would figure you would need the ABS module communication, figure out what it would be at 30mph, and output that. But wait, theres more, the automatic cruise control has a cancel function built into the range sensor. My '02 when it was an auto would cancel cruise if I went into neutral at road speed. You could build a tone ring and sensor for the PTO and figure out the ratio needed for 30+mph minimum for engagement, run those wires to the ABS module as a summed signal, then emulate the output. That would be a bit on the complicated side though and you said make it easier.
Potentiometer confuses you, but you can whip out a word like multisyllabic and use it properly in a sentence?
I don't care who you are that's funny right there
