New Light install (buttload of pics)
Used clear headlights and corner lights from Ebay seller parasitesingle. I recommend using the stock adjusters because the ones that come with it aren't very good quality. Lights fit very well.
I'm planning on getting clear LED's for the corner lights but will get around to that later. I'm using Sylvania Xtra Vission bulbs and I'll get night shots later...
Old Lights:
New Lights:
Compare old vs new:
Remove grill/corner/turn/surround pieces:
Remove header panel, two bolts on each end, one at inside bottom corner of headlight, two each side at ends of grill hole, one bottom center (8mm, 11 total)
What it should look like: (corner/bumper attaches here)
What one side looked like:
Fixed the cracked pieces with JB Weld and sheet metal
3 Headlight clips hold it in, remove and then re-install on new lights
Finished!
Much better!
Old Lights:
New Lights:
Compare old vs new:
Finished!
Much better!
Mine came with them, but from what I hear they aren't hard to install. You can buy the whole kit for $40 from LMC Truck. and the power wire for them runs behind the passenger side kick panel on all the trucks whether they came with the lights or not.
I love them. Makes it look more like a truck. I need some new lenses for them though, they're getting old and cracked.
The seller on Ebay was pretty easy to deal with. They shipped out 2 days after my payment went through and were here within a week. THe shipping cost was a lot, but total price including shipping was reasonable.
The quality of the lenses seem very good. The adjusters aren't as good as the stock pieces but you can re-use the stock parts on the new ones.
It would have gone faster if I didn't have to repair those two holes so I'd say probably 2.5 or 3 hours from start to finish if you didn't have to fix anything.
GreatNorthWoods
21
10-10-2012 09:46 AM
Brown Falcon
29
12-17-2011 12:58 PM
cdrmotorsports
1999 to 2016 Super Duty
22
09-03-2010 12:02 PM
