Excursion won't start
On the 2002 and up trucks that's a dead give away that the battery needs to be replaced. Start there, then work your way back.
Was this problem solved?
I'm having the same or a very similar issue where my Excursion (6.8) is trying to start but won't.
The starter is cranking, battery is strong but the engine won't start.
Seems like it's starved for fuel, but at the same time it also feels like the engine may be flooded (but I doubt that is even possible with fuel injection).
I started noticing this about 2 years ago, but usually if I let it sit for 15 minutes or so it would finally start.
Now it won't start at all despite letting it crank and crank.
All it does is slightly (and I mean barely) change the sound of the engine trying to start.
At one point I was thinking the fuel filter needs to be replaced - I've never replaced it and I've owned it for 6 or more years. It's a 2001.
Ok - got it started.
1st I tried 'priming' the engine by turning the key (and holding for 5 seconds or so) as far as I could w/o actually engaging the starter - I did this 6 times.
Tried to start it - no go.
Then I immediately tried to start it by pressing the gas pedal down about 1 inch or so....the engine coughed a little then started right up.
I am having a similar problem but as of now I can start it. It almost left me stranded. When the engine is warm it wont always start but when we let it sit a a while it starts.But only sometimes it wil ldo this. Is it the fuel pump. I did just change the filter over the summer and only thing I did recently was add some seafoam to the tank. PLEASE HELP
I checked all fuses and relays related to the fuel pump.
Here is what I would suggest when the excursion won't start: have someone turn the ignition key as far as it will go (in the ignition) without actually cranking the engine. While that is happening if your near the rear of the Excursion you should hear the fuel pump engage for a second or two.
If you don't hear the fuel pump start/engage, I would check the fuses and relays related to the fuel pump - that info is in your manual or the online manual. Also, check the fuel pump cutoff switch - info on that is also in the manual.
If all of that checks out, you may need a new fuel pump. I got a quote for $650 to replace the fuel pump, the fuel pump assembly at my local parts store is right around $200.
As I'm sure you know normally the fuel tank has to be dropped (to replace fuel pump) which is out of my league to do it myself. I thought about cutting a hole in the floor, but there are issues with that as well.
I have read some posts that had the same issue and they replaced the pump and many fuel related items and still no luck. I have heard it may be a sensor, cat converter being clogged causing to much back pressure, or the dreaded electrical gremmlin, bad ground. I use my x for towing so I need a bullet proof vehicle. I hope we can figure this out.
BTW, I started having this problem (as you describe) about 2 years ago, but normally if I let it sit for a few minutes it would eventually start.
Then back in October I was stranded at a gas station for about a 1/2 hour before it finally started. I didn't have any other problems that weekend, but then shortly thereafter the problem returned.
As mentioned, now I can't get it to start at all - unless I spray starting fluid into the air intake - then it will start for about 2-3 seconds. As mentioned I went through and checked all the relevant fuses and relays last weekend.
At this point I'm going to have it towed to a repair shop.
#28
Symptoms of a failing fuel pump:
Occasionally, a fuel pump will warn you that it needs to be replaced. It will overheat and stop working for 20 minutes or so. If you let the car sit for a half hour (more or less), it will start again, as the fuel pump cools off and begins working again. If you encounter this symptom, have the fuel system diagnosed to be sure it is the fuel pump and not the relay or wiring causing the problem, and have the offending part replaced.
#29
