Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-14-2010, 01:42 PM
DavidB67 DavidB67 is offline
Garage is empty, add now
DavidB67 is starting off with a positive reputation.
Angry 2007 Expedtion Engine Control Module Help
We just got our 2007 Ford Expedition Limited back from the Ford dealer; they had it in the shop for 27 days!!! The initial problem was that the truck would crank, but not start. After about 3 weeks of "checking everything" they decided to replace the engine control module; it didn't fix the problem. They ended up flying in a Ford tech; he couldn't figure it out. They flew in ANOTHER Ford tech and he determined that it was most likely the fuel pump. The dropped the gas tank and found that the fuel pump had melted to nothing and the cabling going in and out stretching about 1-1/2 foot away had also melted. Per the Ford tech; "You're lucky you had a full tank of gas, otherwise the truck probably would have exploded." When asked what caused the failure, their response; "We have no idea". They also replaced the control module; which had also failed. They socked me with a $1310 bill to replace the fuel pump. The control module was replaced under warranty to "help me out" after the fuel pump bill.
My main issue is that there was a short that caused the fuel pump to melt to nothing and create a potentially deadly situation for my family. I’m not satisfied with their response that they have no idea what caused the problem. I'm trying to find out what exactly the engine control module controls. In the repair order it is listed as “7U7Z-12A650 DRA Module – Engine Control”. If the control module is responsible for electrical control of the fuel pump; then this could have created a faulty control issue with the fuel pump causing it to fail. There were other indicators leading up to this. About 6 months ago, my wife noticed that when she plugged her cell phone charger in the outlet, it would turn the A/C off. About 4 months ago, the truck would not start – similar conditions. The battery was replaced and the truck started working again. I’ve looked around the Internet trying to find data on this, but I’m at a loss. I really need to find an answer to this. The fact that Ford cannot determine what caused it equates, to me, that they cannot guarantee that it’s not going to happen again and we may not be “lucky” enough to have a full tank of gas the next time. After buying Fords since 1986, I'm absolutely disgusted that they assumed such a nonchalant attitude when they told me that we were lucky it didn't explode!
  #2 (permalink)
Old 10-15-2010, 10:27 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I agree, Ford can NOT guarantee that it will not happen again. No one can. If you are worried I would sell the truck. Most techs don't analyze much. Just swap parts.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
Tags
07, 2007, control, ecm, engine, expedition, ford, fuel, location, module, navigator, pump, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
