98 Expedition wire diag for factory amp - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-05-2001, 10:45 AM
kprussel kprussel is offline
kprussel is starting off with a positive reputation.
My 1998 Ford Expedition has a built in (factory ) amplifier which is mounted near the back of the truck. I would like to rewire the existing setup and use my own (Kenwood) amp. Iíve already ran a power cable to the back from the battery. I think the only thing I need to do now is to disconnect the two cables going to the existing amp and somehow change them over to RCA cables, then hook them up to my Kenwood amp. Does anyone have any info on this?
Thanks
Old 02-09-2001, 11:36 PM
turbo497 turbo497 is offline
turbo497 is starting off with a positive reputation.
If it has a ten pin connector it may be the same as the 2000's
this is what the book shows
pin 1 DG/VT subwoofer high audio mute
pin 2 BK/LG Ground
pin 3,4,5 not used
Pin 6 LG/VT power- hot all times
pin 7 BR/OG Subwoofer high audio -
pin 8 RD/BK subwoofer high audio +
Mike
Old 03-24-2001, 10:58 PM
wacarter wacarter is offline
wacarter is starting off with a positive reputation.
Hey Friend,
I too have a 98Exp EB. I want to replace the AMP. How did it go for you installing your Kenwood? Did it work out ok? Any suggestions for a GOOD amp that would sound excellent. Post or e-me. carter7431@netzero.net
Old 03-25-2001, 01:28 PM
jakegypsum's Avatar
jakegypsum jakegypsum is offline
jakegypsum is starting off with a positive reputation.
99 Navigator aftermarket radio no sound from speakers! drhill 1997-2006 Expedition & Navigator 9 06-29-2014 01:49 PM
Installed my Kenwood DNX7190 with iDatalink Maestro rayofsi 2007 - 2014 Expedition & Navigator 11 01-18-2013 03:34 PM
Input Needed: Inverter/Amp install robert_l_ross Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 40 12-24-2011 03:54 PM
A little stereo help please? Airslot Excursion - King of SUVs 19 02-14-2011 08:14 PM
Kenwood DNX5120 in 2007 F250 jeredh Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 23 07-14-2009 09:18 PM
Tags
1997, 1998, 98, amp, amplifier, diagram, disconnect, existing, expedition, f150, facotry, factory, ford, navigator, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
