map sensor - Ford Truck Enthusiasts Forums
map sensor
Old 10-14-2010, 11:33 AM
kirbykoon's Avatar
kirbykoon kirbykoon is offline
kirbykoon is starting off with a positive reputation.
Question map sensor
1992 f150 4x4 5.8 efi 5.8 e40d transmission
can someone please tell me how to tell if the map sensor is bad?
my truck would not idle, i changed the tps,ect, iac. I have checked for vacuum leaks and put in new sparkplugs and wires. if i pull the vacuum line off the map sensor, the engine smooths out and idles fine, but shifts a little rough
Old 10-14-2010, 01:38 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
You could have saved yourself some $$ by first checking for codes: Ford Fuel Injection How To Run a Self-Test
Use this as a reference for checking your MAP sensor: Ford Fuel Injection Manifold Absolute Pressure Sensor (MAP)
Old 10-14-2010, 04:09 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You can also use a tachometer to test it.
If you do not have or cannot afford to buy a hand vacuum pump or tachometer, you may be able to rent one in a major auto parts or equipment rental store.
1. Set the tachometer to the four-cylinder scale
(regardless of how many cylinders the engine has).
2. Connect one tachometer lead to the middle terminal
on the MAP sensor and the other tachometer test
lead to ground.
3. Connect the two jumper cables the same as before,
attaching each end terminal on the sensor to its
respective wire in the wiring connector.
4. If you want to measure engine vacuum so you can
correlate it to a specific frequency reading, connect
a vacuum gauge to a source of manifold vacuum
on the engine, or tee the gauge into the MAP
sensor hose.
5. Turn the ignition ON and note the initial reading.
The reading on the tachometer should be about
454 to 464 at sea level, which corresponds to a
frequency output of 152 to 155 Hz.
6. Start the engine and check the reading again.
If the MAP sensor is functioning properly, the
reading should drop to about 290 to 330 on the
tachometer, which corresponds to a frequency
output of about 93 to 98 Hz. No change would
indicate a defective sensor or leaky or plugged
vacuum hose.
Here is the hook up:
Old 10-14-2010, 05:23 PM
kirbykoon's Avatar
I pulled the codes via ford code reader and here it is
koeo-111
koer-8,412,116,411,538,536,632
**I failed to mention that I got the iac at a wrecking yard,cause I didnt want to spend that much until i knew for sure, but it didnt make a difference,(maybe another bad iac??)
Code 126 94 F 250 5.8 steveamann 1987 - 1996 F150 & Larger F-Series Trucks 17 05-20-2013 07:34 PM
88 5.9L high idle. wskline 1987 - 1996 F150 & Larger F-Series Trucks 3 12-12-2012 10:11 AM
map sensor and poor mpg wendal Modular V8 (4.6L, 5.4L) 7 02-27-2008 06:29 AM
Where is the air intake temp sensor, and MAP located? Kwattro 1987 - 1996 F150 & Larger F-Series Trucks 3 01-17-2006 09:55 PM
Intake air temp sensor location. Gene W 1968-2013 Full Size Vans 10 01-24-2005 09:26 AM
Tags
100, 1992, 2006, 300, 302, 58, 96, efi, f150, f350, ford, map, reading, sensor, tpsiacmap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
