Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 10-14-2010, 07:23 AM
david_jr david_jr is offline
2008 Ford Expedition
david_jr is starting off with a positive reputation.
Question about snow tires
I have been looking for snow tires for my 08 Limited 4X4. Tire Rack recommends a smaller tire for winter for better traction. They list three sizes for my truck: 275/55-20; 255/70-18 and 265/70-18 and in their tutorial they talk about a smaller tire does less "plowing" etc. A set of 20" Blizzaks from TR are $700 plus shipping, mounting and balancing. A set of 18" Blizzaks are $540 plus I would have to buy rims. I found a fairly new set of 4 Blizzaks (allegedly 8K miles on them) locally on Craigs list for $300, but they are not the exact size listed by Tire Rack; they are 255/45-18. Not sure what they came off of, owner alleges moving to SC and no longer needs. Will these work assuming I could score rims for them somewhere?
They also offer the following warning about the TPMS system:
Your vehicle is equipped with a tire pressure monitoring system that requires a sensor to be installed in the tire and wheel assembly for proper operation.
They offer a TPMS monitoring system for $288. Ouch. So if I buy the TR 18" package for 540 plus Mounting balancing & rims, plus TPMS Im looking at about $1K for snows. The 20" tires are actually looking a bit cheaper.
Any thoughts or suggestions would be appreciated.
__________________
Dave
2008 Ford Expedition Limited 4X4
  #2 (permalink)
Old 10-14-2010, 08:33 AM
welfarewagon welfarewagon is offline
Garage is empty, add now
welfarewagon is starting off with a positive reputation.
Wow, I have a lot of answers for that, first off, I run 22" wheels in the summer and in the winter I bought a set of 18" Michelin tires LTX AS 255-70-18 and they ran me through the winter just fine, that being said snow tires might not necessarily be needed just a good all season tire so that may help you on costs.
The tirerack is correct a narrow tire will plow through the snow better, a larger tire will tend to float over the snow, think hydroplaning.
If you look on Ebay you can find a lot of 18" wheel and tire packages used off F-150's and Expeditions, just search under 255-70-18 or 275-65-18 a more common size tire you will find sets mounted and ready to go from $500-900 or if your looking for tires you will find them cheaper. As a matter of fact I just bought a new-used set of tires for the winter on Monday, 4 Michelin LTX AT2's for $500 used. retails for about $1100 new.
18" FORD F150 EXPEDITION FACTORY WHEELS RIMS TIRES: eBay Motors (item 110598120505 end time Oct-16-10 09:50:31 PDT)
For the TPMS you will need to either break down your existing wheels and have the sensors, bands and cradles moved over to whatever winter wheel you use, its a pretty big hassle, come summer you'll have to switch them back again, your best bet is to buy the TPMS as a set from the tirerack or elsewhere online. It will make everything a whole lot smoother, Now you can have a set of summer wheels and tires and winter wheels, the only thing else you will need is a TPMS reset tool, its about the size of a keyless entry fob and can be found on Ebay.Here is one for $9.99.
ford tire pressure reset tool tpms lincoln mercury NEW: eBay Motors (item 280573590873 end time Oct-17-10 09:34:16 PDT)
If you don't use the TPMS you get a warning light on your message center that you can turn off but you will have to do it every time you start your truck using the reset button on the dash.
Hope this helps, if I can answer anything else for you let me know.
BTW I have an extra set of TPMS cradles I'd sell you for $20.00 you still need to buy the bands, clips and straps.
  #3 (permalink)
Old 10-14-2010, 11:23 AM
Thanks for the informative reply. So I'm wondering if the 255/45-18's would work?
__________________
Dave
  #4 (permalink)
Old 10-14-2010, 12:21 PM
T.A. T.A. is offline
T.A. is starting off with a positive reputation.
Quote:
Way too short. That tire is 5" smaller in diameter than th 255/70.
Tire size calculator
  #5 (permalink)
Old 10-14-2010, 01:54 PM
Agreed , a 265-65-18 is even to short I checked into it myself, would throw the speedo off to much. I went with a 275-65-18 which is the F-150 size, its .01 bigger so nothing will be off speedo wise, its much more common.
  #6 (permalink)
Old 10-14-2010, 05:10 PM
Thanks for the calculator. Very eye opening. Looks like the 18 that Tire Rack recommends is very close.
__________________
Dave
  #7 (permalink)
Old 10-14-2010, 05:20 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
I just reach over and turn the selector from 2H to 4A.
But we only get 12 feet of snow here.
-- Chuck
  #8 (permalink)
Old 10-15-2010, 08:32 AM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
The 20" tires might get you anywhere you need to go.
And, as noted, 4wd certainly makes it easier to go.
But I generally have very little trouble going... even on Pittsburgh's steep hills.
Now, stopping & steering are very different, and much more urgent concerns. If you can't go, you can wait. If you can't stop or steer, you can crash. Quickly.
So 18s or 17s are a step towards more control.
But if you're getting tires to use in the winter, why settle for the better compromise of a more appropriately sized all-season when you can put on dedicated snow-biters for the same trouble?
I've driven a 5.0 Mustang through winters in Erie, PA... that's snowbelt land. So I can make things go in the snow, and I'm sure all of you can too. But with my family on-board, why would I settle for mediocrity?
Now, if you can find a turn-key set of 18s or 17s already mounted with the TPMS's inside for much less money, I'd say cost is a good reason to settle for "better" instead of aiming for "best".
__________________
1997 F250HD 4wd, 460-5-speed Ext. Cab, Blue
2007 Navigator L Dark Blue Pearl
2003 Mercury Marauder, Dark Blue Pearl, Trilogy Supercharged, 13.1 @ 105
  #9 (permalink)
Old 10-15-2010, 12:31 PM
It seems that there is no 20's, 18's or 17's turn key with TPMS. For some reason everything I see has had the TPMS removed. Most are "take offs" that were removed for upgraded wheels/tires and the TPMS were either reused on same vehicle or sold seperately. 18 inch snow tires are going to cost around $700 even on ebay. The used ones I saw look really used and I would pay the $120 to 200 shipping most are charging. Add to that a set of rims for 18 (mine are 20) at $300 - 500 and TPMS for $300 and it's looking like a $1500 affair. I could get new Blizzak 20's mounted for around $1K. I was just hoping to find a good junkyard steal I guess, but not too many vehicles around in this size category, let alone for junk. The current Pirelli's only have 18K on them and the dealer puts them at about 70 - 80 % life so I will probably just ride out the winter on these and when its time for these tires to be replaced I'll go for a good set of Michelin M+S. We survived last winter on them and they only have 8 more K miles on them now. Thanks for all the input
__________________
Dave
Tags
2003, 2657018, 2755520, cost, expedition, f150, ford, nwew, pressure, recommended, snow, tire, tires, truck, wheel, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
