Help! code p0611
Old 10-14-2010, 05:02 AM
amsk8er1983's Avatar
amsk8er1983
amsk8er1983 is offline
Help! code p0611
Ok so these last few mornings have been a little chilly. I go to start my excursion and it seems to have a little trouble. It starts and everything it just chugs a little and acts like it wants to die until it catches up. So I run my dtc codes on my edge and I get p0611 ficm performance. So is my ficm taking a crap or would it be something like chaffing wires to the ficm. It seems to drive and idle just fine. Just in the morning when it sits overnight and it cools down. If it is the ficm can I replace it myself or should I have it done since it needs to be reflashed?
Old 10-14-2010, 05:28 AM
bismic's Avatar
bismic
bismic is online now
Received 2,490 Likes on 1,727 Posts
It would be way cheaper to do it yourself and then take it in to be reflashed.
Why not try repairing it?
Old 10-14-2010, 08:06 AM
amsk8er1983
Ok cool I'm going to test it first. So when I put the new one in I can still drive it to get it flashed? Also would it be worth getting a 58volt ficm from like innovative diesel?
Old 10-14-2010, 08:42 AM
69cj's Avatar
69cj
69cj is offline
Check the ficm test and repair sections in the tech folder. I would try to re-solder it 1st. You have nothing to lose. I don't remember the name of the co. but there is a co. selling rebuilt ones for 3 to 4 hundred bucks exchange. Mark may have their name in that endless ream of info that he has accumulated.
Old 10-14-2010, 08:45 AM
amsk8er1983
Ok I might try that has anybody else done? Is it pretty hard?
Old 10-14-2010, 08:47 AM
69cj's Avatar
69cj
69cj is offline
If you or a buddy can solder the directions are pretty straight forward. Do the voltage test procedure 1st.
Old 10-14-2010, 08:50 AM
amsk8er1983
Alright cool what's the chance of some bad injectors would that pop up a different code?
Old 10-14-2010, 08:53 AM
John Irwin's Avatar
John Irwin
John Irwin is offline
When I did mine, I broke the plastic hose connection under the degas tank, and had to replace it for 50 bucks, so my recomendation is to drain the degas and remove it, but maybe you're not as rammy as I am. Mine was all in vain as the solder looked perfect, but I think there's still something wrong with it, although I don't get a code. Getting the wiring connectors apart is probably the hardest part of the job
Five
01-01-2017 07:18 AM
armyprop
07-22-2016 08:35 PM
Rusty Axlerod
01-15-2016 05:48 PM
JCark
11-27-2012 07:34 AM
strokin'_tatsch
02-02-2011 07:28 AM
Quick Reply: Help! code p0611
