how much back spacing would be recommed to run 12.50" wide tires on a 02 f250
The actual offset measurement is independent of width, but not in regards to wheel placement. A 10" wide wheel and a 8" wide wheel with 0 offset will not sit in the same location in the wheel well when mounted. Just as a 10"/8" wide wheel with 4.5" backspacing will not sit in the same location.
I'm just trying to figure out if we are saying the same thing...just from different sides of the fence. Potato...potato.
I think we're saying the same thing. Correct, the outer lip of the wheel will change position with width, but the center of the wheel is only dependent on the offset. The tire placement is only dependent on the center of the wheel as well, so with the same offset, different widths will not change the tread position.
ok what is the stock offset on a 02 superduty because i am runing 285/75R16 on the stock rims right now and at full lock i got about 1/2 space between the tire and the spring i just want a rim that will clear the springs with 12.50 wide tires i will be putting a lift on the truck to run 35x12.50 in years to come when i get the funds to do that i just want new rims for the summer time that can run 33x12.50 because the stocker rims look like sh$% good for winter tho
greentruck72
01-26-2017 11:16 AM
FordIowan
07-02-2012 09:42 PM
BMWM1
1999 to 2016 Super Duty
04-19-2012 10:46 PM
