My 66 F100 Custom Cab LWB Build-up
Well I posted intro a week ago... I've decided I'll be keeping the truck, and fixing it up to be a clean driver. Factory paint scheme was Caribbean Turquoise and Marlin Blue (uncertain of what would've been the main body color any help on this would be great)
To start out with, there's a short in the harness. I found a deal on an EZ Wiring 12circuit harness, and it'll be here within a week. This will be my 3rd complete rewire project with universal harnesses. Still some connectors I need to get before I can get started.
Just figured I'd start a build-thread, so everyone can keep track of any upgrades, mods, etc...
Here's a list of planned mods/upgrades, etc...
This is also going to be a more "long term" project, since I have a few others to finish first, Luckily the body is in great shape, so I could do a complete repaint in a matter of 1-3 weekends (depending on how productive I feel) I'll be keeping detailed pics of every stage, mod/upgrade.
- Complete rewire
- 7pin Trailer Harness
- Elec choke conversion
- Pertronix Ignitor Module
- Proform Electronics Multispark ign. box
- Pertronix Flamethrower Coil
- Power steering
- Power disc brakes
- Automatic Column
- Remove roof-top marker lights
- Complete repaint back in factory color
- Hooker Headers
- March Industries Underdrive Pulley
Started working on more of a tune up to the 352... P.O. replaced plugs that was about it. idle was set far too high, and air mixture needed adjusted. Runs much better now. Still need to check gap on the points, and timing, as it feels a little off.
I went to replace the exhaust flange gaskets, and noticed when looking over the driver's side, there's a large(apprx 2") spacer between the manifold and the exhaust flange. I've never seen this on my previous FE motors (62 Galaxie, 69 Fairlane, etc...) I've not been able to locate the gasket that goes between the spacer and the manifold. I'm really trying to get out of taking it to a local exhaust shop (i'm "cheap", and I don't like other people working on my vehicles) Any help would be appreciated
There is no gasket it is a machined finish and fit. This is the exhaust heat riser valve. Its function is to allow exhaust gases to back up and heat the intake plenum through cross ports from the heads into the intake. If you need a seal high temp red silicone will help but not for long.
It is about useless and jams up easily. It can be replaced with later model aftermarket FE truck exhaust manifolds.
Garbz
Garbz
Getting the parts truck from a good friend, he's had it for nearly 20yrs... It is optioned with the disc up front, and if not, he has a 76 or 77 with power discs. It'll be my choice as to which one I drag home for parts.
Thanks for info on the heat-riser, I'm used to them being on passenger side. I've always removed them, or opted for headers. I have some sources of other manifolds, I'm not willing to try the silicone idea. I want a permanent fix, vs temporary solution. Thanks again.
Went through my spare parts stash; found a set of manifolds from 74 truck. I'll install them tomorrow & have the exhaust cut & reinstalled. Also found one of my spare rebuilt distributors already s setup with pertronix ignitor unit. Also cleaned junk out of the bed... lift up the bedliner & the bed is solid. I will likely pull out the liner clean up the bed & coat it with herculiner.
AutoColorLibrary - Color Chip Selection
--Mike
Here's some pics...
Mess of a hacked up wiring harness...
Toolbox Rust
Doorjamb rust
Can someone tell me what this swith would've been for? Mounted above Gas pedal, only contact when at full throttle. Has 4 prong plug, and 3 wires ran to engine bay ontop of dr. side valve cover. It's not hooked up to anything though.
I did get distributor swapped out today with my pertronix unit installed. But spent most the day getting my Jeep Wrangler back together, where I had to replace a bent axle shaft.
Toolbox Rust
Doorjamb rust
