Heater in 1956 F100
on
Is the motor spinning up hard and fast? I used a 6V motor on mine. I just don't run it on high speed for long periods. What temp thermostat ya running? If the coolant aint hot neither will the heater be. Is the heater valve opening letting the water circulate? Engine is safe to about 195 temp so putting some cardboard in front of part of the radiator works when all else fails. So first we need to know what temp yer engine is running at and go from there Bud. And what engine ya got would help also. Like is it the Y block or something else? Inquiring minds would like to know.
That heater should run you out of that truck. Take the motor out and tear it down and make sure its clean and lubed. Then make sure your core is not clogged with crap. I have some of these heaters so if you need any parts let me know. My email is fifty-two_f1@ndwave.com
ZSK
10-11-2014 09:24 AM
donald mc
11-21-2002 11:32 PM
