Excursion 7.3 4WD - what kind of MPG are you getting? - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 06-25-2013, 09:14 AM
Studawg's Avatar
Studawg Studawg is offline
Thread Ender
Studawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to all
Quote:
Originally Posted by AMG-SM View Post
My mileage improved by about 2 mpg switching back to stock sized highway tires from 285 all terrains fwiw...
Man that really bums me out. I really wanted to go to 285 BFG ATs next time from my 265 Michelins, but 2 MPG?! Thats a good bit.
  #62
Old 06-27-2013, 06:33 AM
9905 9905 is offline
9905 is gaining momentum as a positive member of FTE.9905 is gaining momentum as a positive member of FTE.
need help
Ok, I have had my Excursion for well over a year. I have learned alot, but I still think there is something wrong with it and its fuel economy.
I drive like grandma at 55-60 mph two lane no stops and still can't get over 15 mpg. Besides all the mods in my signature line, I have changed the fuel filter and cleaned the EBPV sensor pipe. Tires are 70 psi. Lie o meter say 20.9 most of the time, math says anywhere between 13.5 and one time 15.9. I recently lost a years worth of avg on my smart phone, but avg for the last 1723 miles is 13.8 mpg.
I have driven mostly highway miles on this last tank and I will be lucky to get 300 miles out of a half a tank.
So where do I start. What all do I need to check and look for. I don't have a auto enginuty and I don't know of anyone that does. I am not really ready to start throwing parts at it either. What are some of the culprits that I can check for please.
Thanks
  #63
Old 06-27-2013, 07:11 AM
Thelhouse Thelhouse is offline
Thelhouse is starting off with a positive reputation.
Dont be offended but make sure your front hubs are not locked in.
I say this because i bought my X 6mon. ago the writing on the hubs was gone afer only getting 13.5 to 14.5 mpg even after some mods i checked them and they were locked in the last tank i avg 15.75 mpg
now that is not great but it is alot better.
  #64
Old 06-27-2013, 09:54 AM
Stebs Stebs is offline
Stebs has a very good reputation on FTE.Stebs has a very good reputation on FTE.Stebs has a very good reputation on FTE.Stebs has a very good reputation on FTE.
Thanks
Take it out and verify the accuracy of the speedometer. You never know if a previous owner changed the tire size or tire size setting in the computer.
  #65
Old 07-07-2013, 07:03 PM
dw200 dw200 is offline
dw200 is starting off with a positive reputation.
I recently brought a 00 Ex out of retirement. It has the 7.3 and is a 4wd. To say it had a hard life would be an understatement. Everything is stock. It gets 17 to 18 mpg on the interstate.
  #66
Old 07-07-2013, 08:00 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
made a trip to OH the other day. Just pulling the car trailer out there I got 19.4mpg. On the way back with a OBS truck on the trailer I got 14.4mpg. This is with a 2wd though. :P
  #67
Old 07-07-2013, 11:28 PM
RavageX's Avatar
RavageX RavageX is offline
RavageX is gaining momentum as a positive member of FTE.
I just finished a trip up interstate 5 and got about 18mpg going 70-80mph. I have 3.73 gears with 35in tires and had rpm at about 2100-2200. Went about 700miles on 7/8th of a tank.
  #68
Old 07-08-2013, 04:55 AM
DavenTn's Avatar
DavenTn DavenTn is offline
DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.DavenTn has a very good reputation on FTE.
Bought my Ex, Ltd. 7.3 4x4 a few weeks ago and drove it home from Nashville to Stuart Florida ('bout 1K miles) @ a steady 70mph... 21.3 mpg hand calculated. Has cold intake and Magna flow dual exhaust. Other than that ... stock. 265 Michilens were real nice tires.
I see many say the mileage decreased by going to a taller tire. My experiences has always been the opposite... slight increase. Wonder why? Anyone care to explain? I do understand if the tire brand changes, air pressure or type of tire could change the mileage in a negative way.
I tow a lot, and this is why I got it, but no numbers yet towing.
  #69
Old 07-08-2013, 06:36 AM
Jmatthews's Avatar
Jmatthews Jmatthews is online now
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
We are in Juno Beach now, lots of Exes down here for sure.
When you use a taller tire it throws the speedo off a bit showing lower mileage. I think taller tires may help on the highway some but hurt in the city.
  #70
Old 02-03-2014, 08:51 PM
ssolid ssolid is offline
ssolid is starting off with a positive reputation.
If the Computer is right...
If it is right I got 33.2 mpg on my way home from work last night over a 39 mile run. 3 Stop lights. One stop sign. Otherwise kept it easy on and off at 1200-1300 rpm (44ish mph).
I must say this is totally managing the driving experience the whole time and adding approximately 20-25 minutes to my drive. Otherwise I am around 16-17.
I have been adding Super Tech TC-W3 Outboard 2-Cycle Oil when I fill up @ 1oz per Gallon of Diesel. I have also added a 203 degree thermostat and an Ingen Cold Air Intake System along with a Banks 4" straight pipe exhaust.
I would like to get a Bully Dog or some other performance Tuner to enhance the driving experience and MPG.
Thanks
  #71
Old 02-05-2014, 04:09 AM
mecdac's Avatar
mecdac mecdac is offline
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Exclamation The Computer is not right
Thanks
It's not, unless it is all down hill.
  #72
Old 02-05-2014, 07:20 AM
Snowseeker's Avatar
I haven't had to put fuel in my X for months now!
  #73
Old 02-05-2014, 07:35 AM
mecdac's Avatar
Wink
Quote:
^^^^^ That right there is funny. ^^^^
But you have been buying some Honda fuel, though.
  #74
Old 02-05-2014, 07:41 AM
Snowseeker's Avatar
yeah, I have had to fill up the honda a few times I guess.
  #75
Old 02-05-2014, 09:20 AM
jayjjcc's Avatar
jayjjcc jayjjcc is offline
jayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to beholdjayjjcc is a splendid one to behold
Thanks
Computer lied to you. Only way to get that MPG with an Ex is to be going downhill in neutral with the engine off...
7.3L turbo down pipe felix4 Ford Truck Parts for Sale 0 10-23-2016 08:34 AM
7.3? Vinford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-02-2015 04:42 PM
Mr.7.3 of Byram Mr. 7.3 of Byram 1999 - 2003 7.3L Power Stroke Diesel 10 01-25-2015 06:22 AM
2000 7.3 Service Manual? nodesy Excursion - King of SUVs 2 01-29-2014 08:57 PM
7.3 retrofit fozzy 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-07-2001 10:20 PM
Tags
2001, 2003, 4wd, 73, chipped, diesel, excursion, ford, fuel, kind, kinda, mileage, mpg, powerstroke, real
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
