Excursion 7.3 4WD - what kind of MPG are you getting? - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 01-14-2011, 09:26 AM
dougger222 dougger222 is offline
dougger222 is gaining momentum as a positive member of FTE.dougger222 is gaining momentum as a positive member of FTE.
Average 16-17 at 75mph, 14-15 city driving.
Best ever was at about 60mph got 19.8mpg on a full tank.
All stock, 220K miles.
  #47
Old 01-14-2011, 11:49 AM
dave91gt dave91gt is offline
dave91gt is gaining momentum as a positive member of FTE.dave91gt is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by SC-Ex View Post
Dave - whats the 2-cycle oil for?
Has anyone improved their mileage with the muffler delete pipe on the stock (no-Cat) exhaust?
Thanks!
I tried the 2 cycle oil for 2 reasons. I read about it tested in Diesel Power and also in the 7.3 forums on this site. It essentially adds lubrication to the injectors from what I remember.
  #48
Old 01-18-2011, 06:23 AM
papadelogan's Avatar
papadelogan papadelogan is offline
Snowboard season cometh..
papadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to beholdpapadelogan is a splendid one to behold
Quote:
The 2cycle oil is to provide lubricity for the injectors. Our 7.3s were not designed to run off ULSD and the injectors can suffer even though additives are supposed to be a part of the formula to cover it. When's the last time the gov't truly covered your butt? Even if it didn't add any MPGs, I'd add it to help my engine run smoother and the injectors to last a bit longer.... a good bit longer.
  #49
Old 01-18-2011, 10:21 AM
Studawg's Avatar
Studawg Studawg is offline
Thread Ender
Studawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to allStudawg is a name known to all
Quote:
I wondered about this ULSD. So, how much 2 cycle oil are you running and where exactly are you putting it, in the gas tank? And how often?
  #50
Old 01-18-2011, 11:29 AM
I am using the $2.00 Supertech from Wal Mart. 1 16 0z per fillup. And yes, directly into the fuel tank at each fill up. As I understand it, that may not be enough. If I recall, some guys are running 1 oz per gallon.
  #51
Old 01-18-2011, 11:55 AM
Studawg's Avatar
Thread Ender
So what, specifically, is in the 2 cycle oil that helps the injectors? Or what does the ULSD not have that our engines are wanting? I am just trying to understand what problems the ULSD can cause and why and what 2 cycle oil does to prevent it. Regardless, I think I am gonna stock up on some of this stuff. Thanks,
  #52
Old 01-18-2011, 02:17 PM
hhcobra hhcobra is offline
hhcobra is gaining momentum as a positive member of FTE.
It's cheaper by the gallon at Wall Mart. What you want is the Outboard motor oil TC-W3. Most put 1/2 ounce per gallon.
  #53
Old 01-18-2011, 02:58 PM
SC-Ex's Avatar
SC-Ex SC-Ex is offline
SC-Ex is starting off with a positive reputation.
OK, SC boys - whats with the 2-stroke oil?
Why?
Any proof behind this theory?
  #54
Old 01-18-2011, 03:04 PM
Studawg's Avatar
Thread Ender
i dont know SC-Ex, thats what Im trying to find out.
  #55
Old 01-18-2011, 03:59 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Why?
It's not a theory. There's plenty of data available on the 'net.
Some guys use 2 stroke oil because it's convenient. Some guys use name brand additives. It's all personal preference.
There was a chart that made the rounds a couple years ago that ranked the different additives for lubricity. I didn't save it but if you do a search over in the 7.3L forum you'll get a ton of reading on the subject, and will probably come across the chart.
Stewart
  #56
Old 06-24-2013, 12:11 PM
Thelhouse Thelhouse is offline
Thelhouse is starting off with a positive reputation.
I have an 01 7.3 4x4, X. I bought it @ 100k miles i have put 11kthe miles on it the only thing it tows is my fam. All my trips are @ least 60 mi. round trip i drive lite on the foot top speed 65mph however my fuel mileage is 13.5 to 14.5 my tires are 285syou the mods are 6637 airfilter, bigboost, edge programer i use setting 3. All this and no change in mileage.
what else can i do??
I am thinking 4in exhaust and electric fan maybe??
  #57
Old 06-24-2013, 05:29 PM
Studawg's Avatar
Thread Ender
Wow, old thread. I sure have learned a lot since I posted here 2.5 years ago!
Anyway, since then, I have averaged around 16 in town, 19 hwy, 14-15 when towing.
How much air in your tires? If they are load range Es, you should be running them at about 70 psi, that could help mileage. Also, your EBPS (exhaust back pressure sensor) tube could be clogged. That can hurt mileage. Also, how are you calculating the mileage?
  #58
Old 06-24-2013, 06:00 PM
Calculating by dividing total miles per tank by gal added @the fill up
going to clean the ebps on Saturday
  #59
Old 06-25-2013, 12:34 AM
AMG-SM AMG-SM is offline
AMG-SM has a good reputation on FTE.AMG-SM has a good reputation on FTE.AMG-SM has a good reputation on FTE.
My mileage improved by about 2 mpg switching back to stock sized highway tires from 285 all terrains fwiw...
  #60
Old 06-25-2013, 04:26 AM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
My mileage went up from 15 to 16.8 consistently around town just by re-ringing the injectors after 185,000 miles. Had 3 blown O-rings and had no signs. On the highway, 19 and have seen 21 twice, all hand calculated. I have a Diablo economy/tow tune on mine. Otherwise all stock.
7.3L turbo down pipe felix4 Ford Truck Parts for Sale 0 10-23-2016 08:34 AM
7.3? Vinford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-02-2015 04:42 PM
Mr.7.3 of Byram Mr. 7.3 of Byram 1999 - 2003 7.3L Power Stroke Diesel 10 01-25-2015 06:22 AM
2000 7.3 Service Manual? nodesy Excursion - King of SUVs 2 01-29-2014 08:57 PM
7.3 retrofit fozzy 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-07-2001 10:20 PM
Tags
2001, 2003, 4wd, 73, chipped, diesel, excursion, ford, fuel, kind, kinda, mileage, mpg, powerstroke, real
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
