Excursion 7.3 4WD - what kind of MPG are you getting? - Page 2 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 10-15-2010, 09:55 AM
ScaldedDog's Avatar
ScaldedDog ScaldedDog is offline
ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.ScaldedDog has a great reputation on FTE.
Wow, how do you guys get such great mileage? My '01 has averaged 14.1 (hand-calc) over the seven years and 57K I've owned it. It's job in life is to go to home depot and towing my 4Runner to Moab, which means several tall passes and 75mph speed limits.
Mark
Old 10-15-2010, 11:21 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
Rushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud ofRushmore X has much to be proud of
Mine probably averages around 18-19 hwy, but I also run about 78mph across the state and had 285's for tires...
Old 10-15-2010, 12:13 PM
Joe28443's Avatar
Joe28443 Joe28443 is offline
Joe28443
Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.Joe28443 has a very good reputation on FTE.
Quote:
Originally Posted by rcboats1 View Post
18-20 city, 22-25 highway as long as I stay below 70 (normaly set cruise at 68). 15-18 towing 6880lb travel trailer.
01 w/ GTP38R, Tymar intake, 4" turbo back, Riffraff IC boots, Edge Evo II, Sinister tank/pre pump kit, other stuff too...
That's impressive! You get better towing a TT than I do on the hwy. I need to get me one of those upgraded turbos if its gonna do all that LOL
Old 10-15-2010, 12:35 PM
rcboats1's Avatar
rcboats1 rcboats1 is offline
rcboats1 is gaining momentum as a positive member of FTE.
The big key for me has been to keep my speeds down. If I start driving over 70 I notice a big drop in MPG.
Old 10-15-2010, 03:48 PM
SD26's Avatar
SD26 SD26 is offline
SD26 is starting off with a positive reputation.
I have 285's. Best mileage I've ever seen, hand calculated and ground speed verified by GPS, was just shy of 19MPG.
Old 10-16-2010, 09:52 AM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Quote:
Originally Posted by Joe28443 View Post
I must have issues, I have a 2wd and see 15 around town and maybe if I am lucky 19 on the hwy @ 60 mph. If I hook up my TT (6000) I see 10 and 11. Maybe I need to go back to stock
That doesn't sound right at all. I as well have a 2wd and have seen as high as 24. Lowest I have gotten was 14.5 pulling my 24'TT and boat at the same time @ 70mph.
Old 10-16-2010, 10:29 AM
shortboxd's Avatar
shortboxd shortboxd is offline
shortboxd is starting off with a positive reputation.
Quote:
The only 7.3-powered Excursion I'd heard of that achieved that kind of mpg was very highly modified to do so, and driven with an egg on the accelerator. What mods have you done to yours to get that kind of mpg (especially towing)? I'm sorry, but I find it highly irregular, and I'm sure even Ford would like to study yours if it is actually achieving that kind of efficiency.
Old 10-16-2010, 10:56 AM
Snowseeker's Avatar
I installed a heater plug, thats it. All stock.
Old 10-16-2010, 01:19 PM
JonWright's Avatar
JonWright JonWright is offline
JonWright is starting off with a positive reputation.
16 to 17 freeway, 11-12 when towing. I'm running 315's. No Mods. How do you guys use your overdrive? I only kick into od when 55+. what should I do to improve the economy to the numbers I'm seeing on this thread?
Old 10-18-2010, 09:28 AM
easpilman easpilman is offline
easpilman is starting off with a positive reputation.
mileage
03 Limited 7.3L
I get 15-17 around town depending on hills and force on the right foot. 21-25 on the highway (same as above) 19ish towing my 25 foot boat. I have a chip, modified intake and exhaust.
Eric
Old 10-18-2010, 10:40 AM
boertje's Avatar
boertje boertje is offline
boertje is starting off with a positive reputation.
Quote:
That's exactly what I am getting but with stock tires. If I can keep it under 70 I can break 20mpg.
Old 10-18-2010, 11:35 AM
SD26's Avatar
Here's my fuel log on Fuelly.com. Includes all of my notes. Haven't been driving the Excursion much since getting a Jetta TDI and then the Excursion being down after the tornado.
The X Fuel-up Log | Fuelly
  #28
Old 10-18-2010, 01:15 PM
dave91gt dave91gt is offline
dave91gt is gaining momentum as a positive member of FTE.dave91gt is gaining momentum as a positive member of FTE.
01 7.3 4X4. Mods in sig. As it is, i average 14-15 mpg in daily driving. I just returned from a trip to Gatlinburg TN and recorded 18 mpg with varying speeds from 60-80 mph. Those are overhead lie-ometer readings. I dont bother with really recording it as I never seem to get the same amount in the tank due to foaming. For that matter, it is so much better than my last X with the V10 that I do not really care what the actual number is. Right now my fuel gauge is a little above half with 340 miles (not corrected for tire change). I am sure the overhead is optimistic. The Nittos seem to have taken a chunk out of the mileage in both increased size and rolling resistance, but they look and perform good.
  #29
Old 10-24-2010, 03:47 PM
Mike_cfi Mike_cfi is offline
Mike_cfi is starting off with a positive reputation.
I have calculated my first couple of tank fulls and I appear to be geting about 12-13 around town and on a trip to Tucson I got 21.
______________
2001 Excursion 7.3 4X4 Stock except for K&N filter
  #30
Old 11-08-2010, 02:32 PM
freesoul freesoul is offline
freesoul has a good reputation on FTE.freesoul has a good reputation on FTE.freesoul has a good reputation on FTE.
I just calculated my last tankful and it was 13.8 around town driving and some highway- no towing, overhead computer said 14.8. I drive pretty light on the pedal, running our own homebrew B100
I was hoping it would be higher....
7.3L turbo down pipe felix4 Ford Truck Parts for Sale 0 10-23-2016 09:34 AM
7.3? Vinford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 11-02-2015 05:42 PM
Mr.7.3 of Byram Mr. 7.3 of Byram 1999 - 2003 7.3L Power Stroke Diesel 10 01-25-2015 07:22 AM
2000 7.3 Service Manual? nodesy Excursion - King of SUVs 2 01-29-2014 09:57 PM
2002 Lariat 7.3 - no gauges will only idle? l_anthony 1999 - 2003 7.3L Power Stroke Diesel 7 07-08-2013 11:57 PM
Tags
2001, 2003, 4wd, 73, chipped, diesel, excursion, ford, fuel, kind, kinda, mileage, mpg, powerstroke, real
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
