Ford F600 What carb? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 10-13-2010, 02:43 PM
zman300 zman300 is offline
zman300 is starting off with a positive reputation.
I have a 78 Ford F600 with the 361.
Has a Holley carb on it. The tag reads Motorcraft D8TE AHA 7L4.
What model Holley is this. I need a rebuild kit.
Thanks
Old 10-13-2010, 08:48 PM
awhtx awhtx is online now
awhtx is gaining momentum as a positive member of FTE.awhtx is gaining momentum as a positive member of FTE.
Look on the air horn for a stamped "List" number. That's the number you need to order Holley kits.
Old 10-14-2010, 06:47 AM
Yep I got the list number. Looked around online couldn't find anything.
So I called Napa gave him the info I had, he ID'd it.
Thanks
Old 10-14-2010, 09:12 AM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
NAPA part # is 25819 for rebuild kit , it is not a Holley carb ! it is a motorcraft carb , ford copied the Holley some parts may interchange though ! with all those big trucks NAPA is the best place to get parts
Old 10-14-2010, 09:57 AM
Quote:
That's weird. It says Holley on it.
Old 10-15-2010, 06:16 AM
Dennis/Ohio Dennis/Ohio is offline
Dennis/Ohio is starting off with a positive reputation.
Quote:
I've lost many favorites links with computer problems but I couldn't find a Holly kit number once (GMC C7000). Went to Holley website, got tech assistance 800# called for kit number, ordered kit from summit racing. It's bazzar what you can order from Summit racing with a good part number. They may not have a clue what it is but they can order it.
Old 10-15-2010, 12:51 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
It is a Holley carb, and since it was factory installed on a Ford truck, it will have a Motorcraft part number.
I will type the Ford & Motorcraft part numbers for the carb & carb kit when I return from Hawaii on the 18th.
Old 10-16-2010, 04:04 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
Holley
It should be a Holley 2bbl with a governor that is a 2300-G
Old 10-18-2010, 04:30 PM
Thanks
D8TE-AHA = D8TZ9510AH .. Holley 4V Carburetor (Motorcraft CA2003) / Obsolete
D8PZ9A586P .. Holley 4V Carburetor Kit (Motorcraft CT1232) / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 607-722-5371.
BOWMAN SALES & SERVICE in Bowman ND has ONE = 701-523-3257.
GREEN SALES CO. in Cincinnati OH has TWO = 800-543-4959.
Old 07-21-2011, 05:12 PM
jahlbrandt jahlbrandt is offline
jahlbrandt is starting off with a positive reputation.
What Carb for 1972 F700 361 Ford
I have a high mileage 1972 F700 cabover with a very tired carb. The engine is a 361. Will a (replacement) Holley 2- barrel series 2300 fit on it, and if so, would a 350 or 500 cfm be better?
F-600 292 cid carburator jonixon 1957 - 1960 F100 & Larger F-Series Trucks 4 01-21-2017 09:40 AM
400 jetting advice/ Holley 600 ktm4012 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 07-04-2016 06:20 AM
Holley Carb to Edelbrock manifold sony420 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-29-2015 12:54 AM
Holley 600 carb on fe 360? brigga72 1967 - 1972 F-100 & Larger F-Series Trucks 2 07-23-2011 08:35 PM
Worth rebuilding this Holley? BlackCustom77 Fuel Injection, Carburetion & Fuel System 7 06-29-2010 12:27 AM
Tags
1981, 2300, 2300g, 2v, 361, aha, carburetor, club, d8te, f600, ford, gas, holley, parts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
