Tire Rating D vs E rating - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 10-13-2010, 03:37 PM
rmrichards949's Avatar
rmrichards949 rmrichards949 is offline
rmrichards949 is starting off with a positive reputation.
What's the big difference between 'D-rated' vs 'E-rated tires. My initial thought was E-rated tires had a higher load range that D-rated tires. But after shopping around I found that, that is not always the case.
For instance if I was going to go back to original 265/75/R16 E with BFG ATs the specs are
Max Load =3,415 lbs
Max PSI = 80psi
Tread Depth = 16/32
Overall Dia = 31.7"
Or if I go with a bigger tire, then a BFG ATs @ 295/75/R16 D-rated is
Max Load = 3,415 lbs
Max PSI = 65psi
Tread Depth = 17/32
Overall Dia = 33.2"
Is the D/E rating only telling how many plies are on the sidewall? And is there any advantage to running E's (which I would think is preferable), like tire roll around corners.
Thanks
Old 10-13-2010, 05:32 PM
6_Myles 6_Myles is offline
6_Myles is starting off with a positive reputation.
E ratings have stiffer (and usually shorter) sidewalls which make towing a little bit less bouncy and helps control sway.
Old 10-13-2010, 07:04 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
The letter designation indicates the number of plys or actually the equivalent strength based on early bias ply tires.
D = 8
E = 10
There are tires that (obviously given the example) can share the same Load Index but have different Load Range designation. The most important is the former.
Basically the main difference between those two tires is one's ability to hold 80psi.
While I'm not a tire expert, seems to me that the D has to be as strong or maybe stronger to hold the same weight using less pressure. However it's taller sidewall could be a hindrance in stable towing.
Old 10-13-2010, 07:57 PM
shortboxd's Avatar
shortboxd shortboxd is offline
shortboxd is starting off with a positive reputation.
Quote:
Ford recalled Excursion diesels to replace the D's and put E-rated tires on them. It was certainly not done because the D tire was as strong or stronger.
Old 10-13-2010, 08:03 PM
Monsta's Avatar
No, those particular "D"s had a lower Load Index than the "E"s that went on. I know, my 2000 was part of the recall.
It's been said before that those "D"s were fine for the application. They well exceeded the GVWR of the Excursion. Ford put them on in (another) attempt to soften the ride. The "E"s went on due to the Explorer fiasco.
Old 10-13-2010, 10:41 PM
So basically the general concensus is that, the E's have less tire roll due to more tire pressure and stiff sidewalls, even though the capacity maybe the same or close. This makes cornering and towing more pleasurable with the E rated tires then.
Prepping to buy some tires and going bigger and I had run across this is some specs and thought I would ask. Having trouble finding some E rated tires in a 16" rim with a overall diameter of between 33.5 and 35". Anyone know of a good tire in that range that handles well and does not have a lot of road noise. I have been looking at BFG ATs (1st choice but can't find in the size I need), hankooks, nitto terras, goodyear duras. Anyone have any recommendations?
Thanks
Old 10-14-2010, 09:51 AM
bigtexan99 bigtexan99 is offline
bigtexan99 is gaining momentum as a positive member of FTE.bigtexan99 is gaining momentum as a positive member of FTE.
I have Nitto Terra Graplers in the E range. I'm not sure about the overall diameter.
they are great tires, but they wear fairly quickly. About 50,000 miles is all you are going to get out of them. They wear quickly because they grip good.
Old 10-14-2010, 12:42 PM
profro profro is offline
profro is starting off with a positive reputation.
Quote:
That has been my experience
Old 10-14-2010, 01:08 PM
bnuvp bnuvp is offline
bnuvp is starting off with a positive reputation.
I found E really improved the ride and handling on my EX.
Old 10-14-2010, 07:41 PM
malolo malolo is offline
malolo is starting off with a positive reputation.
I put 285/75/16 michelin ATX AT2 E rated on my 2005 EX and the ride is great. they replaced 265/75/16 D rated Yokohamas
Old 10-17-2010, 10:54 PM
kitebuz kitebuz is offline
kitebuz is starting off with a positive reputation.
I just put on Firestone Destination AT 285/75/16's Load e, and am very happy w/ them so far.
My opinion & review of G.Y. Duratrac vs Silent Armor IcutMetl Brakes, Steering, Suspension, Tires, & Wheels 10 04-18-2013 06:36 PM
tires again... D vs E RACERX7775 Excursion - King of SUVs 46 12-31-2011 12:45 PM
Confusing allowable weight stickers Boomer23059 1999 to 2016 Super Duty 55 07-24-2011 12:07 AM
Need Tires, A Good 35" A/T or M/T. Help! seminaryranger 1999 to 2016 Super Duty 12 04-26-2011 09:56 PM
Toyo open country A/T vs. Nitto Terra Grappler Benchwrench 1999 to 2016 Super Duty 35 01-23-2010 10:28 AM
Tags
2657516, de, difference, excursion, ford, load, ply, range, rated, rating, tire, tires, towing, truck, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
