Transfer case fluid change
Old 10-13-2010, 09:31 AM
LRSTony's Avatar
LRSTony
LRSTony is offline
i'm going to change the transfer case fluid in my 2005 excursion diesel. should i use the same fluid that i used in the transmission or can i just use royal purple atf?
Old 10-13-2010, 12:52 PM
ljutic ss's Avatar
ljutic ss
ljutic ss is offline
It calls for Mercon ATF about 2 quarts.
Old 10-13-2010, 01:05 PM
smokersteve's Avatar
smokersteve
smokersteve is offline
Yea you can use it. Put The front of the truck higher than the rear so that you can get some extra oil out.
I used amsoil and I really like it. And when I changed my fluid I needed 2-2.2 Quarts.
Old 10-14-2010, 07:00 PM
Jayybird's Avatar
Jayybird
Jayybird is offline
I used mobile 1 atf, so far so good. I've read a lot about folks using RP, I think its preference...IMO, just keep changed about every 30k and u should be fine.
