'67 F100 paint schemes. - Ford Truck Enthusiasts Forums
Old 10-12-2010, 11:31 PM
fettless fettless is offline
fettless is starting off with a positive reputation.
Is there a visual reference that exists for factory paint schemes for different paint/trim options? I want to paint my '67 to factory specs, I know my truck was/is blue and white...I want to know exactly where the truck was blue and where the truck was white from the factory.
Thanks, Jeff
Old 10-24-2010, 09:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Post the COLOR codes found on the Warranty Plate, and I'll tell you how the truck was originally painted.
Old 10-25-2010, 06:27 PM
Paint is M7. M, I know is Wimbledon white. The 7 is a little confusing, closest I have found is Harbor Blue. The Ditzler chart shows Harbor Blue as a mettalic. To me the truck appears Peacock Blue?
I want to know where the white cuts off in the jambs (factory). If the top was indeed white from the factory and exactly where the color stops (factory).
Jeff
Old 10-25-2010, 11:19 PM
Austy's Avatar
Austy Austy is offline
Austy is starting off with a positive reputation.
Is there some program or site where you can virtually see your paint scheme?
Old 10-25-2010, 11:46 PM
M7: M = Wimbledon White / 7 = Harbor Blue aka Dark Blue.
The primary color is listed first on the Warranty Plate.
This means that the roof and below the upper side mouldings was white, while the center section was blue.
Paint info is from the official 1967 Ford car/truck paint chart, which also has the chips glued to it. This chart was used at the Ford parts counter.
Old 11-02-2010, 10:57 PM
TNTRUCKS TNTRUCKS is offline
TNTRUCKS is starting off with a positive reputation.
Did all the two tone trucks in 67 apply the bottom color to the cab roof? I ask because I have a 67 ranger that is black and white. Black as the top color and white as the bottom color, but the top of the cab is black and not white. Was this changed at some point or was that an option?
Old 11-06-2010, 12:15 AM
I guess I threw a curve ball with that question...........sorry
Old 11-06-2010, 07:14 AM
Quote:
Raven Black = COLOR code A / Wimbledon White = COLOR code M
How are these COLOR codes listed on the Warranty Plate? Like this: AM ... or like this MA?
The primary color is listed first, so if the cab roof is black, below the upper side mouldings would also be black.
The center section (above the upper side mouldings) would be painted white.
The COLOR codes on the Warranty Plate will be AM with this paint scheme.
No curve was thrown. I was in Hawaii from 11/2 thru 11/19, so I didn't see this question originally.
1964 F100 2 Tone Factory paint scheme David1964 1961 - 1966 F-100 & Larger F-Series Trucks 8 03-08-2015 06:26 PM
1964 F100 Styleside "Custom Cab" paint scheme David1964 1961 - 1963 F100 Unibody 0 11-08-2014 08:14 AM
1957 paint scheme, any experts? truckin457s 1957 - 1960 F100 & Larger F-Series Trucks 0 02-08-2014 09:27 PM
2 tone paint opinions Roelito78 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-08-2010 09:38 AM
54: Sungate Ivory Grill Paint -- can't find paint jack71 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-07-2006 02:05 AM
Tags
1967, 67, blue, chips, codes, color, f100, f150, ford, harbor, paint, schemes, specs, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
