Transmission Bump
Transmission Bump
Hey Gents,
Recently bought a Used 2010 F350 SD 4x4, 5.4L, 3.73, extended cab long bed. It had 9100 miles on it. After buying it I noticed when stopping just before a complete stop at a light I felt a little movement underneath the truck. Also, when accelerating to go a little jump accurred. I kept notice of this and seemed like the transmission or almost like a u-joint.
The warrenty transferred to me and so I took it to my local Ford dealer. Service adviser said sounds like "transmission bump". It was in for service and adviser said they reset the software and also for 2003-2010 there is a TSB on this. He said Ford wants a little movement in there at stop and before take off for some reason.
Drove it home and it seemed to be better than it was but still slightly noticeable. I need to drive it more. Adviser said if it gets worse or different then let him know.
Just curious if anyone else has had this or are they blowing smoke?.
Appreciate any replys.
You might ask if they are familiar with TSB 05-26-10; slip yoke, as mentioned, may need XG-8 grease. Of course, that TSB does not specifically apply to your truck year model, but . . . .
Some will say they were not machined to the correct dimension; Ford should cover the "clunk" under warranty.
Carnes99
16
02-17-2015 10:50 PM
Cylesdale
06-15-2011 07:42 AM
Rocker7700
1997-2006 Expedition & Navigator
24
05-18-2008 10:19 PM
