Fuse # 19 keeps frying
Old 10-11-2010, 09:04 PM
trike1946's Avatar
trike1946
trike1946 is offline
Question Fuse # 19 keeps frying
I have a 2001 F 250 7.3 diesel. It is running really bad. It keeps frying fuse #19 which is for the fuel pump motor/PCM. Is there a way to separate these to check where the problem is? It goes bad in less than a minute. Is there a plug in the fuel pump I could disconnect then put in a new fuse to see if it goes and narrow it down to the PCM? Does the PCM kill fuses when it goes bad?
It is a 20 amp under the hood.
Thanks for any help.
Old 10-12-2010, 10:32 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
You could go back to the fuel tank and unplug the pump from there.
Old 10-12-2010, 10:50 AM
trike1946's Avatar
trike1946
Thanks for the reply. Is it on the frame next to the tank?
Old 10-12-2010, 11:37 AM
trike1946's Avatar
trike1946
OK I found the pump. It was towards the front. I started looking at pulling the wires off and saw a plug about a foot away that the wires ran into. In looking at the plug I noticed about 2 inches up was a bare spot on the red wire and it was laying on the brake line. There are only 2 wires. One black and the red with a stripe. Would that be enough to do it? Can I just tape it up or does it need something special?
Old 10-12-2010, 04:53 PM
Franklin2's Avatar
Franklin2
I bet that's it. I would tape it up and see what happens. I think the other line to the PCM is just a input to the PCM so it can verify the pump is getting power.
Old 10-12-2010, 05:44 PM
trike1946's Avatar
trike1946
Bingo. A stupid little thing like that killed the truck. I taped it up and started the truck. Sounded fine. I took it out and it ran great. Thanks for the help.
gonzales
1997 - 2003 F150
16
01-06-2017 09:25 AM
mysuperduty89
1999 to 2016 Super Duty
04-09-2016 06:50 AM
CRAZYC123
08-26-2011 10:02 PM
Mastagunz
1983 - 2012 Ranger & B-Series
08-25-2011 09:19 PM
cajunbull61
2004 - 2008 F150
02-17-2009 07:01 PM
Quick Reply: Fuse # 19 keeps frying
