What octane for a 239 flattie?
Old 02-16-2003, 05:56 PM
KEITHS 1950 F68's Avatar
KEITHS 1950 F68
KEITHS 1950 F68 is offline
Question What octane for a 239 flattie?
Hey guys and gals;
Should I be putting the really expensive gas, or the really, really expensive gas in my flathead 239?
I haven't done anything about the no lead thing yet; but apart from that, should I be burning premium or regular fuel? Anybody with any suggestions about what works for them?
Thanks.
Old 02-17-2003, 12:09 AM
mtflat's Avatar
mtflat
mtflat is offline
If you're running a 52 or 53 without hardened valve seats you might want to use a lead substitute, but otherwise it'll run on anything.
I just returned from a 550 mile trip and ran 85.5 octane regular unleaded with no problems including pulling hard up mountain passes with about 500 lbs in the box.
Unless your motor is built for performance - high comp heads or radical cam, you should be good with regular pump gas. IMHO
Old 02-17-2003, 01:28 AM
KEITHS 1950 F68
Tim;
Thanks; I'll go with the 'cheap' ($0.83Can per Canadian gal) stuff.
Keith.
Old 02-19-2003, 08:02 AM
STEVE1103's Avatar
STEVE1103
STEVE1103 is offline
My 53 Merc seems to run better with the 87, costs a little more than the 85 but does eliminate the stumble I was getting.
Old 02-27-2003, 05:45 PM
41Clay's Avatar
41Clay
41Clay is offline
As I hear it, you are subbposed to use the octain in occordance with your compression, 8.5:1 compression=85 octane gas. Since the falttys came with about 6.5:1 compression the cheapest would be fine, unless you upped the compression and timming (alot) then the higher octane would be wise.
Clayton
Old 02-28-2003, 02:42 PM
KEITHS 1950 F68
Clayton; Sounds like a good formula. Thanks......Keith.
abe
12-25-2015 05:33 PM
keyvangarcia239
10-19-2014 07:46 AM
keyvangarcia239
10-06-2013 04:56 PM
john fin
06-20-2008 05:19 PM
NJ239Y
08-24-2003 05:22 AM
Quick Reply: What octane for a 239 flattie?
