clutch bypass
clutch bypass
Hi guys. I installed a remote start/alarm combo this weekend, and I need to bypass the clutch to use my remote start. I would like to wire the bypass on a switch. Anyone done this before? I saw an older thread on this, but the end result was having non functioning cruise control. Thanks in advance for the help.
By Jockd's list it would be 3 and 4...to make a jumper harness you would you would have to jumper the white/pink and the dark blue/orange for the starter circuit to work and jumper red/yellow and tan/light blue for the cruse to work
I cant find a print anywhere so I am assuming jockd's beak out is correct, you should be able to play with it and make it work.
#1) WH/PK is +12V power
#2) DB/OG is output to starter
#3) RD/YE is cruise control input +12V
#4) TN/LB is output to cruise control
#5) WH/PK is +12V power (May be jumpered to #1)
#6) GY/YE is signal to PCM (Gas Engine Only)
